Question about Western Digital WD1600AVBB 160GB 7200 RPM ATA Hard Drive
I have this hard drive in my DVR box, but the problem is, it come up saying "Record Fault!!! No HDD to Write!!!" I have plug it to my pc and format it and then place it back into my DVR box in order for our CCTV to start Recording asap, but again same message of "RECORD FAULTS!!! NO HDD TO WRITE!!! come up. I have order new HDD same as my old one but same message come up including formatting it, same message. I am clueless as to what to do next, if any one can help me solve this I would appreciate it.
    Master:
  • 966 Answers
Disconnect from PC.
Reconnect DVR to TV after a minute. Does it record? It will initialize etc before recording.
Posted on Aug 04, 2013
Can you record from a smart tv with arecording box
First of all you need to check if your TV supports recording. Some 2010 models do and most 2011 have it implemented. Look for stickers or logos such as:
  • USB Recording
  • PVR (Personal Video Recorder)
  • DVR (Digital Video Recorder
  • The following manufacturers support it in some of their models. Typically mid-end to high-end models. Check the manufacturer web site if you are unsure.
  • Samsung
  • Sony
  • LG
  • Philips
  • Panasonic
  • Toshiba
  • Sharp (only Time Shift pausing)
  • Grundig
    What you need
    Many consumers have USB recording enabled TVs without actually using the function - simply because it requires an extra USB hard drive ou need the following:
    1. USB Recording: A HDTV that supports recording.
    2. A USB HDD: FlatpanelsHD uses a USB HDD from Transcend.
    3. Digital channels: Recording is only enabled on digital channels - not analog. You can record SD, HD and 3D.
    Some manufacturers recommend USB hard drives with external power supplies but we have used a Trandscend USB HDD that takes power from the USB plug on all manufacturers' TVs without any problems. Manufacturers typically allow 1:1 recording, meaning that you will see no loss in picture quality.
    How to set up USB Recording
    Once you have purchased a USB hard drive and connected it on the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  • Connect the USB HDD to a free USB port on the back of the TV.
  • The USB hard drive now needs to be formatted (all data will be deleted).
  • Most TVs help you to format the USB HDD automatically but on some models you need to enter the menu and select format HDD (or something similar)
  • Sep 29, 2016 | Televison & Video
    Drive windows format
    ignore the format thing, totally.
    its MS way of telling you , its seems corrupted.
    what system? PC, dvr, MAC, laptop.
    what OS, windozs what,? xp,w7.w8?
    the FreeAgent is and external HDD.
    1: is the power pack plugged in?
    2:is the led indicator dead on HDD.
    3: did you try all USB ports.
    4: did you try it on another system.? and USB port?
    5: did you look in disk manager to see if it shows up, say DISK2?
    6: did you ever drop it?
    Oct 05, 2013 | Seagate 500GB FreeAgent GoFlex Hard Drive
    Swan dvr wont record
    It sounds like a problem that might be an easy fix. Since the system CCA board doesn't see the HDD. Can you view any previously recorded images? How are the connections to the drive? Bad IDE ribbon cable (yes do do fault), power to the HDD and how about the drive? Some of my DVRs require the manufacturer drive, not a simple off the shelf (i.e. Lanex or Verint).
    Try that and reply back. :)
    May 22, 2013 | Home Security
    Lorex-edge model no lh314 series will not record and beeps and says hdd is not installed
    You need top open the top of the case by removing the screws and check to see if the hard drive is operating (it will be warm to the touch and may be making a slight noise). If the hard drive is not working, verify that it is plugged in. If the hard drive is bad, you can replace it with a SATA hard drive. The Lorex system will see the new hard drive and ask you to format it for use with the system.
    Feb 02, 2013 | Lorex EDGE L314501C4 4-Channel Network...
    I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
    Guys this one stumped me for some time, here is my solution that worked like a dream
    1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
    2. Delete all partitions
    3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
    MANUFACTURER MODEL CAPACITY ROTATION
    ST3320613AS 320GB 7200 rpm
    ST33500320AS 500GB 7200 rpm
    ST3750330AS 750GB 7200 rpm
    Seagate
    ST31000340AS 1000GB 7200 rpm
    WD3200AAKS 320GB 7200 rpm
    WD5000AACS 500GB 7200 rpm
    WD6400AAKS 640GB 7200 rpm
    WD7500AAKS 750GB 7200 rpm
    WD10EADS 1TB 7200 rpm
    WD15EADS 1.5TB 7200 rpm
    WD
    WD20EADS 2TB 7200 rpm
    Maxtor STM3500320AS 500GB 7200 rpm
    STM3750330AS 750GB 7200 rpm
    HITACHI HDT725032VLA360 320GB 7200 rpm
    HDS721010KLA330 1000GB 7200 rpm
    FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
    Cheers.
    Jan 11, 2013 | Home Security
    I have a Lorex edge LH314 320GB, DVR beeps and displays HDD is not formated.
    You need to format the hard drive using the built in formatting utlity. Did you replace the hard drive in the DVR maybe?
    Nov 15, 2012 | Lorex EDGE L314501C4 4-Channel Network...
    My system says no hdd detected. how do u fix this
    a few possibilities:
    hard drive plug came disconnected somehow
    hard drive plug/wires are bad
    hard drive is shot.
    you may want to try to contact the manufacturer before attempting to open it to find the problem, if your hard drive is bad you will probably need to get the operating system/format programming to load onto a new hard drive. best bet is to find a contact for them and see if they sell replacement parts, my guess is the hard drive is bad. it happens, it sucks, and it can be expensive, the upside is if you are careful and take your time it is usually pretty easy to take the bad one out and put a nwe one in... good luck
    Sep 01, 2012 | SWANN 4-channel/camera Dvr Surveillance...
    All saved recordings have disappeared from menu. system has reset itself and now all recording in the HDD play menu have disapperaed. They must still be on the HDD because nothing else has been...
    dissambling and taking the hard drive out of the dvr will most likely void the warrenty how it is possible.
    once the hard drive is removed you may be able to plug it into your PC and gain access to the files on the hard drive. These how ever may be specially encoded and protected files that you cant open.
    -you PVR may have also done a hard reset and formatted the hard drive. This would delete all the files on the PVR.
    -unlike tapes, erasing a hard drive does not require you to record over it. just because nothing else has been recorded does not mean your data is still there. sorry.
    Mar 01, 2011 | Pioneer DVR-720H-S DVD/HDD Recorder
    I want to record a film off my camcorder directly on to the hard drive of my Panasonic DVR-645H-S DVD recorder. I have put the input plugs at the front of the recorder from the camera but cannot get a...
    You have to select the correct External Input, on TV, you do NOT use "Channels" Then select correct format either NTSC or PAL, turn on camera to play, then you should be OK.
    Mar 07, 2010 | Pioneer DVR-645H-S DVD/HDD Recorder
    Formatting disks for EDSR1600
    The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
    If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
    If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
    Do NOT set any drive to Slave!
    Lock the drive trays; if you don't the DVR will not go into record.
    Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
    Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
    Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
    Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
    Western Digital WD1600AVBB 160GB 7200 RPM ATA Hard Drive Logo
    42 people viewed this question
    Top Western Digital Computers & Internet Experts
    Marcin
    Mike
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
