Question about Avanquest System Suite 8: Windows
I BOUGHT FIX-IT SYSTEM SUITE AT WALMART. I INSTALLED IT IN JANUARY 2013, USED IT COUPLE OF MONTHS. AFTER AN AUTOMATIC UPDATE TO AD0BE, SYSTEM SUITE WOULD NOR RUN. i TRY TO RUN THE INSTALLATION DISC FOR SYSTEM SUITE. 1. LEFT CLICK "INSTALL SYSTEM SUITE" 2. IF YOU STARTED THIS PGM ....CLICK CONTINUE 3. MESSAGE "WAIT WHILE PREPARE YOUR INSTALLATION" 4. BOX COMES UP WITH MESSAGE "MODIFY PGM WELCOME THIS PGM LETS YOU MODIFY CURRENT INSTALLATION" REMOVE ALL PGM FEATURES INSTALLED BY PREVIOUS SETUP 5. CLICK NEXT 6. UNINSTALL STATE DO YOU WANT TO REMOVE ALL SYSTEM SUITE.... CLICK YES 7. SYSTEM SUITE-IDS FINISH INSTALLATION SYSTEM SUITE-IDS FINISH INSTALLATION 8. CLICK IDS FINISH i GO BACK TO STEP 1, 2, 3. AT STEP 4, THE ONLY CHOICE I HAVE IS TO MODIFY PGM. IF I SELECT THAT OPTION, THE PROCESS REPEATS, ie UNINSTALLS, BUT NEVER INSTALLS. HOW DO I REINSTALL MY SYSTEM SUITE FROM MY DISC? JDKINARD123@WMCONNECT.COM 405 343 2214
  • 13 Answers
SOURCE: I'm tryingto uninstall System Suite 8
on the unistaller screen select the program
try to unistall it them remove the entry
them go to your (hard drive)=(C:\) and open the folder name (program files) select the folder containing the program you try to uninstall and delete the folder containing that particular program
Note: be carefull not to delete the folder name (program files) make sure the folder your deleting is the one containing (the system suite 8)
Posted on Jan 11, 2009
ariyoso
  • 145 Answers
SOURCE: can't run easy update due to firewall - how do i fix this?
just disable the firewall first, but don't let the other security tools down
Posted on May 27, 2009
hakimmadina_
  • 155 Answers
SOURCE: When I try uninstalling system suite 8 it tells me
Restart you computer and when it's going to switch on press F8 several times until safemode displays. Click safemode then just follow path by ticking OK or yes. Go to user account that you always log on. Mouse over start menu and click control panel. Open Add/Remove program and uninstall from there suite 8. Then restart.
Posted on Jun 22, 2009
SOURCE: I've downloaded Fix-it 10. It won't install until
Well in that case go to the Program Dir find the Folder it is in, and simply Delete the files, delete them all, then remove delete that Dir, Now try a reinstall. Either that or in that Directory look for the uninstall exe file and double click on that and try that way first... else remove them all.
Posted on Feb 19, 2010
SOURCE: trying to install fix-it utilities 10, I am
  • Hello how are you
How to uninstall deepfrez?
Posted on Mar 15, 2010
I bought a used laptop with Windows 7 and came with office 2013. The auto update downloads the updates and shows the prompt"installation failed" , 10 or more times. Can this be fixed?
This worked for me, hopefully for you also.
*Fix Windows Update*
Control Panel
Administrative Tools
Services
Windows Update - Automatic
Windows Module - Automatic
If it doesn't download UNLOCKER http://filehippo.com/download_unlocker/ then delete the folder.
Then download FREE CCLEANER https://www.piriform.com/ccleaner/download run registry and delete all problems also run CLEANER and delete everything no matter how many problems it shows.
Oct 08, 2015 | Toshiba Satellite Computers & Internet
Can't open the lens and it's always low battery
It would appear to be the battery or the battery contacts. Clean the contacts on the battery and recharge the battery. If still does not charge then get a new battery
Dec 17, 2013 | Olympus Sz-12 14mp Wide-angle With 24x...
Emerson TV won't turn on
Check your power strip or surge protector connections if that don't work then you might need to replace the wall outlet.
Aug 14, 2013 | Televison & Video
I can no longer plug the charger in my TracFone to recharge
First off look into the charging port on your TracFone. If there is anything lodged in it then try to remove it with a paper clip or by blowing. Next look to see if the pin in the charging port (could also be a small rectangle, like the top of a flat screwdriver) is bent or broken. If so the phone is broken. Finally look at your charger, if it is bent or broken, try to find another charger to test the phone with
Mar 06, 2013 | tracfone.com
I haven't used this camcorder in a couple of months (bought new in January). When I went to charge it last night, neither the mains charger or USB lead will charge it. Does it just need a new...
The battery should be good if it was bought in January, with that said nothing is nperfect or lasts forever, there are always issues with some things. If all your connections from the charger or USB are good and tight and the cables are good, the either the battery is bad or the plug in on the camera is bad, or the battery nmay be installed incorrectly. That is about all there can be .
Jun 03, 2011 | Cameras
I bought a educationa CD's and while installing it on my home PC where i have installed winxp sp-2 2003 edition i get a error poping up stating this error "iexpress setup has encountered a problem...
Your WINDOWS XP SP-2 needs a WINDOWS UPDATE. make sure you are connected to the internet. then click "START", click CONTROL PANEL, then SYSTEM, and find the AUTOMATIC UPDATES TAB. turn on AUTOMATIC UPDATES. if the updates are already automatic, click the link provided in the tab that brings you to the windows update/microsoft update website. Click express settings. If an option POPS UP, saying "DOWNLOAD MICROSOFT UPDATES" click this option and allow your computer to download this UPDATE. if not, continue by clicking the EXPRESS SETTINGS, the windows website will check to see if your computer is UPDATED. You WINDOWS XP OPERATING SYSTEM should have SERVICE PACK 3, continue this process until ALL UPDATES are installed. You may be required to restart your computer to finish updates.DOING THIS will update drivers as well, which most likely needs to be done in order for the CD to work properly.
Nov 22, 2010 | Computers & Internet
Adobe reader repair was recommended in a simple update procedure....never before happened
If all you need is a PDF reader and you don't want the associated annoyances and problems that Ad0be is burdened with, download Foxit Reader via this link: -
http://download.cnet.com/Foxit-Reader/3000-10743_4-10313206.html
It's free and does a great job. Then simply uninstall this oversized problematic Ad0be Acr0bat reader.
Apr 17, 2010 | Microsoft Computers & Internet
I bought an Elliptical on january 7 2009. It not
This is normal stuff with the cheaper stuff. You need to the lube the joint all the time to get rid of the noise. Contact you local walmart they will get you in touch with their service provider. Best of luck
howard
aaafitness.net
Oct 08, 2009 | Exercise & Fitness
Avanquest System Suite 8: Windows Logo
Top Avanquest Computers & Internet Experts
Joseph Hoffmann
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
