Samsung LCD bn68 01212a Picture is generally too
Samsung LCD bn68 01212a Picture is generally too big and border is cut off and unviewable.
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
How to make the picture cover the entire screen
I have a Samsung Monitor - TV with control buttons with option to hard set screen to 16:9 Check yours, around the border. generally low right-
Jul 13, 2014 | Insignia 42" LCD Flat-Panel HDTV
We recently bought a Samsung 500 Series 46" LCD
make sure you have the aspect ratio set at 16:9.
Mar 23, 2011 | Samsung Televison & Video
TV picture is oversized and we cannot correct it. Heads and borders are cut off.
Confirm that your source(s) are set to "widescreen" or "16:9". If you have the remote, use the "wide" button to cycle through the aspect settings. One setting should look better than the rest, without cutting off any of the picture.
If you continue to have issues, please list the source and source material you are viewing.
Jan 06, 2011 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
PICTURE WONT FIT ALL CHANNELS
Look for the button labeled format , zoom, aspect or picture size and press it until picture is the size you want.
Mar 25, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Gray borders on the HD channels
Have you tried to change the screen size? To do that press the "Psize" button on the remote till you find what you need.
Dec 29, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Picture size is always too big. No matter what the zoom setting or display setting, the image borders fall outside the screen. AKAKI tech support tel # is diconnected.
there are only normally 4 options for picture size, 4:3, 16:9, 16:9 zoom and auto, unless you are using High definition. Any other settings should be found in your cable reciever box as the picture size can be altered in its settings also.
Jul 30, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
