Question about Pentair Great White Lift Brush GW9517
Stays in one place - Pentair Great White Lift Brush GW9517
HENRY VACUUM CLEANER HI LO SWITCH BROKEN CAN I DISABLE IT TO STAY IN HI MODE?
It can be disabled to stay in high mode, but you need to know what you are doing. It basically involves removing the small PCB and connecting the motor wires directly to the on/off switch. The hi/lo switch can be left in place (although not connected) or removed and a blanking plate put in it's place. You can leave a hole as this is a potential hazard and against government regulations.
Feb 28, 2015 | Numatic Henry Bagged Canister Vacuum
I can't get the filter to stay in after cleaning
Hi Patty, it's Jack at Dyson.
DC59 Motorhead's pre-filter is engineered to easy to remove for its monthly wash, but should also stay in place securely once it's replaced. In use, the filter will be held in place by the vacuum's powerful suction. When carrying the vacuum from room to room, we'd recommend keeping the machine horizontal, and to avoid carrying it upside down or vertically. It's also worth checking that the black rubber seal itself is clean and correctly positioned.
If the issue continues, I would encourage you to contact our experts directly so we can provide further assistance. You can reach us by calling 1-866-693-9766 (US) or 1-877-397-6622 (CA).
Jan 31, 2015 | Dyson DC59 Motorhead Bagless Cordless...
SteamVac F5914-900 SpinScrub won't stay upright or collect water
(1) Upright: Sounds like the tab on the lower handle that the handel release latches to has broken off. The machine is fully functional without it otherwise.
(2) Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The cannister won't stay/lock in place
there should be a release for the dirt cup at the top.make sure it in all the way and snapped shut
Apr 28, 2009 | Vacuums
The water won't stay in the tank...
you will have to replace the complete water tank assy. i have tried without any luck to get this valve to stay in place.
Oct 01, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
New belt didn't stay in place
make sure belt lifter is on proper setting/ turning until stops/check right size belt
Sep 06, 2008 | Kirby G6 Bagged Upright Vacuum
Shampooer
If it is falling off (and lodging itself into the hose) I would suggest gluing it in place on the tank...a super glue should keep it in place and there is no reason to remove it. If its glued to the tank there is less chance of it being damaged.
Feb 18, 2008 | Kirby Ultimate G Bagged Upright Vacuum
ASSEMBLING BRUSH HOLDER TO STAY IN PLACE
try thehooverstore this online site has your machine with exploded diagrams. you should be able to figure out how it goes together
Apr 29, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Pentair Great White Lift Brush GW9517 Logo
23 people viewed this question
Top Pentair Vacuums Experts
Are you a Pentair Vacuum Expert? Answer questions, earn points and help others
