Question about Cisco ME 3400-24TS-24 (ME340024TSA)
Reset cisco 3400 - Cisco ME 3400-24TS-24 (ME340024TSA)
How do you reset your router?
There are 2 common ways to reset your router.
  1. By pressing the power button off then back on or
  2. Pushing a pin into a small hole on the back of the router. This will HARD reset your router
  3. and If you want to buy brand new Cisco routers/switches with big discount, you could choose Router-Switch.com
Cisco Router Cisco Switch New Used Cisco Prices Comparison
Oct 26, 2017 | Computers & Internet
How to change a Cisco router password?
If you forget the default password for the Cisco router, first you will need to reset the router for default settings.
After resetting your Cisco router to default settings, go and access the configuration page using the IP address 192.168.0.1
After successful login to Cisco router login page, go for the "Menu" and from here you can find the option to change the password for the Cisco router.
other question, you can visit http://www.router-switch.com/, you can also buy brand new Cisco routers/switches with big discount here.
thank you
Oct 20, 2017 | Cisco Computers & Internet
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
Reset cisco aironet 350 adapter
Try Putty and a 9pin male to RJ45 RS232 serial console cable.
the instructions are in the link provided here:
http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
Jun 30, 2017 | Computers & Internet
Configure
I'd start by resetting the switch to defaults with the command
  • erase startup-config
  • The restart the switch with reload
  • Once rebooted enter conf conf t
  • Then simply configure all the ports at once
  • int ra fa0/1 - 24 if they are gig ports then it would be int ra gi0/1 - 24
  • Then type no shut
  • That should be all you need.
May 22, 2013 | Cisco ME 3400-24TS - switch - 24 ports
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
Oct 27, 2012 | Cisco SG200-26 24 10/100/1000 Ports,...
Blue screen while connecting Cisco switch
Update drivers that control your PC. If problem still persists then use a system utility tool like RegInOut, it will fix the following problems in your PC:
  • Application runtime errors
  • Windows crashes
  • Blue Screen of Death (BSOD)/ STOP Errors
  • Automatic system reboots
  • Failure to start your computer
  • Programs refuse to start
Hope it works for you.
Jan 04, 2012 | Dell Vostro 3400 14" Laptop (V34004168ABS)...
Default username & password after hard reset
Username:[none]
Password:Cisco or
:root
:Cisco or
:Cisco
:Cisco
Try from above 3 then you can access cisco router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 01, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco ME 3400-24TS-24 (ME340024TSA) Logo
22 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
