Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
Elkay EZFSTL8, Unit stops water flow until compressor cools down, (compressor overload?). If we take compressor out of the mix everything else works, with warm water being dispenced.
2 Suggested Answers
  • 127 Answers
SOURCE: water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Posted on Oct 18, 2009
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
Kenmore 596.50692001 side by side stopped cooling. The fan is working, the compressor kicks on for less than a minute then kicks out. No cooling air flows. Water dispenser is working fine, but the water...
You most likely have a fried overload, it is the small white square shaped piece on the compressor, to tell if it is bad, remove it and smell it for electric burning smell, or if you shake it and it sounds like sand shaking around it is definately bad. costs around $25 to replace. You can purchas this at http://www.reliableparts.com/ using your model number.
Dec 01, 2010 | Kenmore Refrigerators
The Amana refigerator I have stopped cooling. There is power to the unit, the lights work but the unit is not cooling. The unit clicks every few minutes.
Start capacitor,start relay, overload and windings in compressor need checked. When clicking like that the compressor is overheating and could damage the internal overload. Send model number so I may tell you the correct parts. I will be here if you need, Sea Breeze
Jan 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
I have a 13500 Dometic roof mounted ducted AC on my motorhome. I have changed the Board twice and the thermostat once and the same problem occures. When you first put the AC on it works fine until it goes...
May need start capacitor and relay (called start kit) or some of the compressors have a thermal overload under the compressor cap. If it's a thermal overload, it has a bimetal disc and when it reaches a set temperature (hot) the disc will warp opening the compressor circuit and not allowing the compressor to come on till it has cooled down. if this is the case then the compressor is not getting enough refrigerant back to it to keep it cool or it's drawing high amps.
Feb 24, 2009 | Heating & Cooling
Compressor starts then shuts down like head pressure building to high
Make sure that your condenser fan is working. If your unit is water cooled make sure you have water flow.
Nov 05, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
89 people viewed this question
Top Elkay Plumbing Experts
jdthefixer
rdjagger
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
