Question about Fujitsu 24C1 Air Conditioner
Fujitsu ASY12RSE-W. Unit not working at all. Timer lamp blinking & operation lamp flashing twice
    Problem Solver:
  • 19 Answers
It's showing an error code for the outdoor unit no communication from the outdoor circuit board.
Posted on Oct 01, 2013
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
  • 81 Answers
SOURCE: The timer light flashes twice about every 15 seconds
This may mean that the filters may need to be cleaned. According to service manual the unit has a "Serial reverse transfer
error at start up operation". Call fujitsu for service if the fault cannot be rectified.
I take the time to answer your questions, please rate me
Mat
Posted on Aug 28, 2009
  • 288 Answers
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Posted on Dec 15, 2009
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
  • 10 Answers
SOURCE: I have a fujitsu asta18lcc when you turn it on
Below is an extract straight from the fujitsu service manual:
Compressor location error
The compressor speed does not synchronze with the control signal. (Including start up failure of the compressor).
> permanent stop.
[Diagnosis Point]
Check if 2-way valve or 3-way valve is left open.
Check the compressor (Winding resistance value, loose lead wire).
Refrigeration cycle defective (Refer to after mentioned "refrigerant cycle diagnosis")
Posted on Jul 15, 2010
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Timer light flashes twice on my asta09lcc but it wont work
If operation light is normal and timer light flashes twice, the error is:
Serial signal (reverse) error, at operation start up
Most likely a faulty outdoor controller PCB. Around $250 for new board plus labour.
Jul 09, 2012 | Fujitsu 18C1 Air Conditioner
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
Mat
Aug 28, 2009 | Fujitsu Heating & Cooling
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
I have Fujitsu air conditioner Model abt45rba3w Serial t000147 The unit will not operate. The red operation light is flashing fast continuously and the a/c unit will not turn on. The timer light is...
Have you checked for compressor operation? If it is not running you may need to replace the hard start relay/capacitor. If you remove it and get the numbers it is available on ebay for a fair price. eBayeBay
Sep 07, 2017 | Fujitsu Heating & Cooling
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
Jun 24, 2008 | Fujitsu Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
318 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
