Question about Furniture
I I have Dihl wine cooler WF-18SS that now longer
I I have Dihl wine cooler WF-18SS that now longer switches on. i have looked at the power supply unit and have noted that the 240V seems to be there but no low voltage DC. Also one of the power transistors is getting extremely hot as well. Do dihl have spare parts anyware? as i it looks like they no longer exist
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 27 Answers
SOURCE: U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
Posted on Jun 21, 2008
  • 3 Answers
SOURCE: Emerson FR24RD Wine Cooler
If you are handy with small electrics, or know someone who is...
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Posted on Jan 16, 2009
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
Hi. I have a Dihl WF-21SS Reviews and the temperature LEDs doesn't display correctly. Can it be fixed???
Here are the possible solutions if they don't fix it, you will want to find the authorized repair company as it is a control board issue.
1. Remove all your wine and beer and place it in your regular refrigerator.
2. Unplug this refrigerator and leave it alone for 24 - 48 hours.
3. Go purchase a refrigerator thermometer and put in in the refrigerator.
3. Plug the refrigerator back in and set it to the temp you like to keep it at. Do not put anything back into the refrigerator yet.
4. Check the temp of the refrigerator against the refrigerator thermometer - it is not unusual for the thermometers to be a couple of degrees in difference. If everything is acceptable, only place the wine back on the racks, leave the beer in the other refrigerator. Let it run for a week and see if it stays balanced.
Or - if upon initial check you find the two thermometers not agreeing you can do one of two things.
A. Best option - contact authorized repair and have them come fix it.
B. Leave the refrigerator thermometer in the fridge and adjust the display panel until the temp in the refrigerator is where you want it on the refrigerator thermometer.
C. Dispose or replace the refrigerator.
Note: I don't suggest overloading your refrigerator.
The original owner's manual is available here (I believe the last two letters designate the finish for example SS = stainless steel).
DIHL WF 21BD Instruction Manual
Best wishes,
Joe
Aug 25, 2016 | Washing Machines
DIHL WF-32DB repair
go onto their web site it will tell you the parts distributor
Jul 13, 2014 | Furniture
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
Power supply failing on Cuisinart CWC 1600 cooler
The hayni made in china internal power supply has faulty transformers on it that fail within anywhere from 6 months to 2 years. Solution. Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box and it only cost 15 dollars. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. Now my wine cooler is more energy efficient and and will run for at least 5-10 years. This power supply replacement takes about 20 minutes. You need: philips screw driver, wire cutter and stripper, two 16 guage wire nuts. That's it.
Oct 12, 2012 | Cuisinart CWC1600 Wine Cooler
I have a DIHL CF-18TN wine cooler which seems rather noisy . Can you help
You might want to post this question in the wine coolers section so that the proper expert sees it.
Sep 02, 2012 | Compaq Presario CQ5110F (NP185AA ABA) PC...
Instruction manual for dihl wine cooler 32 bottles
i have a dihl 21 bottle dual control wine cooler. the temperature display keeps flashing and won't set, this is now happening with both top and bottom ... how do i fix it
May 18, 2012 | Refrigerators
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
Where can I get a Haier swwitching power supply
Call 800-313-8495 for Haier Parts Dept.
The upper and lower are 2 different part numbers.
Jan 31, 2010 | Haier Refrigerators
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Nov 02, 2009 | Refrigerators
Wine cooler Doesn't work
I had the same issue on a Whynter WC28S SNO 28 Bottle Wine Cooler, it even seems like most of the thermoelectric wine coolers, fridges, and such have the same boards by hanny. For cross refference parts I used NTE because Fry's Electronics had them.
Switching transistors - NTE51
1N 4007 - NTE125
Silicon Dual Power Rectifier - NTE6090
Also I have a venotemp wine cooler that has pretty much the same board, with the same plugs for fans, light, control panal, and cooler fan for $45 shipped at their site under replacement parts. Hope this helps people looking for info on this. Also research Switching Power Supply issues for information.
Oct 26, 2009 | Refrigerators
Furniture Logo
943 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
