Question about Canon imageRUNNER 3300i Printer
I need to change the toner cartridge on a older copier, a Canon 3300i. i can't figure out how to remove the old toner cartridge.
    Scholar:
    New Friend:
  • 134 Answers
  • Unplug the unit from the source of electricity. Open the front cover located on the face of the unit.
  • Locate the blue lever in front of the toner cartridge. You will be able to see it clearly when you look through the opening originally covered by the front cover.
  • Pull the blue lever down gently. Do not use force. It is easy to manipulate and just needs a gentle pull.4
  • Look for the blue handle that is on the toner box. Grasp the handle firmly and pull it. The toner box will move toward you. Remove the toner box until it cannot go any farther. The handle is easy to manipulate, so do not tug at it, just pull it gently.
    If you will need more help you can download the service manual for ir 3300i is always good to have a service manual you can download it from the below link:
    http://goo.gl/8glrBm
    Good luck
  • Posted on Jul 31, 2013
    SOURCE: Actually a Canon PC-65, problem follow-up
    canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
    Posted on Mar 19, 2008
    • 24 Answers
    SOURCE: canon copier 3300i error code E000007-0000
    Change the fixing film! It is broken!
    Posted on Nov 16, 2008
    • 61 Answers
    SOURCE: Empty toner waste cartridge
    http://www.fixyourownprinter.com/forums/printer/31918
    Posted on Mar 30, 2009
    SOURCE: Installing the toner cartridge
    release the 'clamshell' and slide it in. I don't know what else to tell you
    Posted on Jul 27, 2009
    • 134 Answers
    SOURCE: where is the waste toner receptacle located on the canon IR 3300i
    Lower rear right portion has a small vertical panel held by one screw. The waste bottle is behind this panel.
    Posted on Aug 13, 2009
    Can't figure out how to change te cartridge on a canon imagerunner 3300 copier problem
    hi
    Follow the steps below to replace a toner cartridge.
    1.Turn the printer on.
    2.Open cover
    3.Push up the right lever to unlock the toner cartridge.
    4.Remove the toner cartridge from the printer.
    5.Take the new toner cartridge out of its package and gently shake the toner cartridge as shown below.
    6.Hold the tag and gently pull the toner seal upward and remove it.
    7.Insert the cartridge all the way until it stops securely with the arrow mark on the top of the toner cartridge facing
    8.Push down the right lever to lock the toner cartridge.
    Aug 02, 2010 | Office Equipment & Supplies
    Remove toner
    you push in on the front top where the stop strip was and it will pop up unless you have yet to add toner to the developing hoppper then you would fallow the directions on the toner box
    Mar 17, 2010 | Canon ImageRunner 3320N Copier
    Changed toner cartridge and still not printing entire page- mostly white space. How can I tell if it is a faulty new cartridge or problems with my copier. There is toner dust inside the copier from when...
    First you need to vacume the spilled toner, especially on transfer roller, eaven clean the transfer roller contacts.
    Try to reinstall the old crg., shake it so that you may get few copies for checking it. If print is OK then its problem in new crg.
    Feb 23, 2010 | Canon imageCLASS D320 Digital Copier
    How do i change the print cartridge?
    Replacing the print cartridge
    1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
    2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
    3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
    4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
    5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
    NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
    Sep 13, 2009 | HP Office Equipment & Supplies
    Where is the waste toner receptacle located on the canon IR 3300i
    Aug 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
    Where is the waste toner receptacle located on the canon ir 3300i?
    there is a rectangle panel on the lower left side of the machine remove the screw in it and the bottle is inside there. you have to clean the top and reboot the machine for the message to go away.
    Jul 28, 2009 | Canon Office Equipment & Supplies
    Jul 26, 2009 | Canon Office Equipment & Supplies
    Toner
    Open front toner door, it's on the top right of machine. Pull old cartridge out, pull orange tape off end of new cartridge and slide it in.
    Oct 27, 2008 | Canon imageRUNNER 400S Copier
    Canon Imagerunner C2050 changing toner
    Did remove all of the packing off the cartridge before installing the cartridge. Also, is it the right type of cartridge for that you need and or the right color... It should be easy to install if you are installing the right cartridge... Good Luck
    May 12, 2008 | Office Equipment & Supplies
    Replacing Canon PC720 Toner cartridge change
    Not sure if you found this out yet.
    The cartridge just slides out. When you lift the latch you will see the cartridge has lifted too. All you need to do is pull the cartridge toward you. It slides right out.
    Jan 13, 2008 | Office Equipment & Supplies
    Canon imageRUNNER 3300i Printer Logo
    27 people viewed this question
    old marine
    old marine
