Question about Craftsman Garden
Craftsman weedwacker mod# 316.711200
Weed trimmer will idle just fine, but stall when i try to accerate. i change the both fuel & air filters,spark plug(.25 gap)& the fuel. still have the same problem. i purchase it on aug 2,2012, according to manual theres a two year warranty associated with this equipment, any solutions....
5 Suggested Answers
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
  • 57 Answers
SOURCE: Spark plug gap?
.030
Posted on May 18, 2009
digritz
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
dan5268
  • 542 Answers
SOURCE: My craftsman push mower won't start, I changed the spark plug, I need to download the owners manual for help. The model @ is 917.373981
Here is the manual for your Craftsman
Posted on Apr 11, 2012
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Air filter replacement weed eater
on your weed eater there should be a lil bubble looking thing called the primer somewhere around tht should be a black box with a screw of some sort on it take the lid to the black box of and theres your air filter
Aug 17, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
I installed a new carburator on a craftsman 25cc weedwacker model 358796600 and it wont't start
You might want to Google the model number for a service manual or contact a sears service parts center for help.
Jun 17, 2012 | Craftsman 25cc Gas Line Trimmer
Craftsman weed wacker wont start
have you drained out all the old fuel and tried fresh fuel gas is only good for 30days in small engines
Jun 08, 2012 | Craftsman WeedWacker Gas Trimmer 25cc...
Weedeater starsts and ildes won't run or accerate
It sems to me like your engine chokes itself on a too rich fuel mix, a clogged air filter may cause this condition. Of course there is always the possibility of a needed carburetor adjustment but I would definitely check the air filter first if this machine used to work fine.
May 30, 2009 | Troy Bilt Tb70ss Gas Trimmer
Runs fine when first start. Dosen't want to start after warmed up.
Have you checked or Changed the Fuel Filter.
It will be in the tank hooked to the fuel line. I suggest a small pair of Hemostats for this job.
May 25, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
449 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
