Question about Kitchen Ranges
Cannon rhapsody gas fire manual
Im looking for a ignition control wire for a cannon rhapsody fire GC number 32-010-07
3 Suggested Answers
  • 1314 Answers
SOURCE: Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Posted on Jan 18, 2008
SOURCE: Cannon Caress gas fire manual
yes go to ths link, took me ages to find but when i put in hte serial number it can straight up, but can you tell me where to buy the replacement coals? heres your link:
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/190.pdf
Posted on Jan 02, 2010
I need a manual for a cannon inset gas fire to see how the coals should be arranged. It's a cannon 26730g. needs servicing and engineer wont look without a photo /copy of how the coals go.
Google the make and model of heater or go to cannon wedsite for manuals The gas fitter can take a picture of the coals before starting the job its not that hard if he cannot do this the find some one else .
Oct 04, 2016 | Heating & Cooling
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
My generator is getting no fire to the plug
The unit has a magneto that is item 16 part number
ETQ1200TG33 on page 22 of the manual link below. You will have to start looking at wires from the magneto / electronic ignition unit to the engine off / run switch for grounds. The unit also has an igniter inside the control panel that is item 2 on page 24 of the manual. The engine run switch is item 4 same page. The high voltage set (coil) is item 28 of the manual link below. Any ONE of these can cause the problem. I would first check the start run switch... then start looking for system grounds in the wiring of the ignition circuit.
Eastern Tools support number is here:
For repairs and missing parts please contact customer support at 1-888-908-6200
Manual is here:
http://easterntools.com/manual_pdf/tg1200_manual.pdf
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Eastern Tools And Equipment 1200 Watt...
My friend has a 1993 geo tracker 4 cyl with an automatic transmission. We have put a brand new ignition coil in and a brand new distributor also. It is getting gas and wants to start but it does not start...
check the fireing order make sure you have the plug wires in the right spot if they are and still dosent start its probley out of time take your number 1 sprak plug out hould your finger over the hole have your friend click the motor over till it blows your finger out if you then look down at the crank line your timming mark up then take the distributor cap loose the rotor button should be pointed at the number 1wire im not sure what the fireing order is but it is usely stamp on the intake
Sep 08, 2011 | 1993 Geo Tracker
IM TRYING TO FIGURE OUT WHATS WRONG.I WAS DRIVING AND MY 89 TOYOTA PICKUP 3.0 4X4 QUIT RUNNING.WE FIGURED OUT FIRE WASNT GETTING TO THE PLUGS.WE INSTALLED CAP,ROTOR BUTTON,WIRES,DISTRIBUTER,AND IGNITION...
will try to help.try checking the ignitor assesmbly,with out it your truck will not get fire or low fire,so low you won't catch it. the ignitor gives it an extra boost of fire to ignite the gas in the cylinders. try that,but if it checks bad,used ignitors must match numbers with old onr. try used auto parts online. hope this helps and thank you for choosing fixya.com
Nov 28, 2010 | 1989 Toyota Pickup SR5
How do i light the pilot light on my Cannon Fitzroy gas log fire
Users manual link attched. This is for the built in put operating instructions should be the same for free standing.
Cheers, hope it helps.
http://www.sampfordixl.com.au/cannon/upload/CannonFitzroyProfilePowerflue.pdf
Jul 26, 2010 | Heating & Cooling
I have atwood GC6aa-9e, will not fire the ignition tries 3 sets
Have you tried temporarily removing the thermal cut-out from the circuit to see if ignites then? It's the little resistor looking thing inside the plastic sleeve/cover that runs to thermostat. Disconnect it from the thermostat terminal, and from wire that is on the other end, and you should be left with a female spade connector at end of that wire. Connect that directly to thermostat terminal where the other part was connected, and try it. If it works, the thermal cut out is no good and needs to be replaced for safety reasons, in case of flame out of control, it blows and shuts gas valve off.
Jun 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Intalled an overhead 130K BTU Mr. Heater last
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Dec 01, 2009 | Mr. Heater Heating & Cooling
Oct 28, 2009 | Cannon Kitchen Ranges
Igniter
igniter's are bad and, or, a short in the wiring or switch. replace the igniter, then check to see if problem still exists, you can also check wires going from igniter to switch with ohm meter for continuity and shorted wires.
Nov 18, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
Kitchen Ranges Logo
127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
