Question about Dell Inspiron 1501 Notebook
How to check media cable - Dell Inspiron 1501 Notebook
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 27 Answers
Click the link below and enter your computer full id name (example) :HP Presario V3000 (RU937PA#UUF)and click search...as simple as 1.2.3,go to this link Hp Compaq drivers for your PC hope this helps :).
Posted on Jul 30, 2013
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD optical device
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
Msi cr700 media fail check cable
Hello, ihave same model MSI CR700 and have same problem, on booting up it says media failure check cable. Im try reinstal windows but freazed on instaling, Im try instal Ubuntu on USB stick and is working, I can see my disc but is like empty but yesterday there was all my files and no problem to opened files and pictures. what you thing problem in harddrive, cable, conector or motherboard. thanks
May 01, 2012 | MSI CR700-012US (816909061604) PC Notebook
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
Media read error check cable
Your computer tries to boot from various devices:
* CD-ROM
* disk-drive
* USB memory-stick
* 3.5" diskette
* network
in some order that has been configured (either at the factory, or by you, during BIOS SETUP).
So, if there is no media in the CD-ROM, no media in the diskette drive, no connected USB drive, then it will boot from either the network (if there is a network-cable that is connected to a "boot-server" system) or from the disk-drive.
So, is your disk-drive getting power?
Is the "data" cable between the motherboard and the disk-drive connected?
Is the disk-drive "dead" (not spinning) ?
Check your disk-drive.
You may need to purchase a new disk-drive, connect it, and reinstall Windows.
Apr 02, 2010 | Gateway MD2614u Notebook
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
Problem:ther's a media test failure. check the cable, what's recommend move
Check the cable.
Seriously, how about some more information? What kind of Mac? What media? What were you doing when you got this message? What device were you trying to use? An external DVD drive? A printer? A RAID array? A DVR?
Apr 19, 2009 | Computers & Internet
Media Cable Failed check cable
Just check the hard disk cable that it is fitted properly in the hard disk and in the motherboard also.
OR
You buy another cable for hard disk which is called 80 conductor cable.
Jan 31, 2009 | Compaq Deskpro 2000 PC Desktop
Error E02E02
E02E02
Roll media set sensor error
<Cause>
This is displayed when the roll media set sensor could not detect positional changes by the paper guide during the paper guide opening and closing operations.
<Probable problem locations>
Roll media set sensor, roll media tray unit, roll drive unit, motor driver PCB, engine controller, system controller
<Remedy>
1.Visual check
Remove any foreign objects adhering to the roll media set sensor.
2.Roll media set sensor
Check operation using SERVICE MODE>I/O DISPLAY, and replace if anything does not function normally.
3.Cable connection check
Replace the cable between the roll media set sensor and engine controller if the connection is not functioning normally.
4.Roll media tray unit
Replace the unit if a visual check reveals that the gears are damaged, deformed, or otherwise do not function normally.
Replace the unit if an operation check reveals that the roll release lever does not function normally.
5.Roll drive unit
6.Cable connection check
Replace the cable between the roll drive unit and motor driver PCB if the connection is not functioning normally.
7.Replace the motor driver PCB.
8.Cable connection check
Replace the cable between the motor driver PCB and engine controller if the connection is not functioning normally.
9.Replace the engine controller.
10. Replace the system controller.
Dec 08, 2008 | Canon imagePROGRAF W8200 InkJet Printer
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Dell Inspiron 1501 Notebook Logo
19 people viewed this question
Alun Cox
