Question about 2002 Hyundai Elantra - All Elantra models - Leather Steering Wheel Covers
Where is the fuel filter situated on the hyundai elantra 2002 1.6 model
    Problem Solver:
  • 18 Answers
The fuel filter is located near the firewall - driver side, under the master cylinder
Posted on Oct 22, 2013
Where is the gas filter on a2006 Hyundai elantra
The fuel filter on this model is not serviceable. There is a small sock filter inside the gas tank.
Jul 27, 2014 | 2006 Hyundai Elantra
How do you replace filter for 2006 Hyundai elantra
The fuel delivery system integrates the fuel filter with the in-tank fuel pump. To service this filter, remove the fuel pump that is in the gas tank.
Does a 2002 hyundai elantra has fuel injectors ?
Yes it does. A fuel injector is a device that atomizes and then delivers the fuel into the cylinder just before the piston squeezes the fuel and air mixture and the spark from the spark plug fires. Ergo your 2000 Hyundai Elantra being a 4 cylinder vehicle, has 4 fuel injectors.
Jun 22, 2014 | 2000 Hyundai Elantra
2002 hyundai elantra car is cranking over but won,t start it has gas you can hear the fuel pump come on don,t know what to check next
seems like a fuel pressure issue, try replacing the fuel filter with a new one, and spray some aerostart into the air intake while cranking over.
Oct 09, 2012 | Hyundai Motor 2002 Elantra
My 2002 hyundai elantra won't start. We put in a new air filter and the air line. But it still won't turn on. What could it be/
Someone will need to figure out if you are dealing with a no spark or no fuel problem to proceed.
Oct 04, 2012 | Hyundai Motor 2002 Elantra
Hyundai stalls and will not start for several hours
MAKE SURE YOU HEAR FUEL PUMP RUNNING IF NOT REPLACE FUSE AND RELAY. CHECK FOR FUEL PRESSURE.IT SHOULD BE 43 PSI.IF NOT REPLACE FUEL FILTER.IF PROBLEM STILL EXIST FUEL PUMP THE PROBLEM.
Aug 27, 2009 | 2002 Hyundai Accent
How to change 2001 Hyundai Elantra GLS 4-Door Sedan Fuel Filter
If the filter is not at the tank, under the access panel, under the rear seat, then it is inside the tank.
May 01, 2009 | 2001 Hyundai Elantra
Took transmission pan off and can't find filter
2002 Hyundai Elantra has 2 trans filters. One is inside the pan which is mounted vertically. The other is located on top of the transmission case.
Apr 22, 2009 | Hyundai Motor 2002 Elantra
I , i try to find the fuel filter for my hyundai elantra 2001
The fuel filter is located under the rear seat in a compartment above the fuel tank. Also, a filter sock at the base of the fuel pump located
in the fuel tank.
On 2001 models the fuel filter is part of the fuel pump. To replace the fuel filter, disconnect the negative battery cable, remove the back seat and take fuel pump cover off to get to the fuel pump.Then you have to 1) disconnect the electrical connector from fuel pump/fuel sending unit, 2) disconnect the high pressure hose and the fuel return hose from the fuel pump and 3) remove the fuel pump mounting flange screws. You can then lift the fuel pump and replace the filter.
Good luck and hope this helps
Apr 19, 2009 | 2001 Hyundai Elantra
Replacing fuel filter
The fuel filter is in the tank on these models. You should be able to get to it through an access panel underneath the back seat.
Oct 28, 2008 | 2007 Hyundai Elantra Limited Sedan
2002 Hyundai Elantra - All Elantra models - Leather Steering Wheel Covers Logo
113 people viewed this question
Top Wheelskins Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
RAYMONDO1953
john h
Are you a Wheelskins Vehicle Part and Accessory Expert? Answer questions, earn points and help others
