Question about CDA Microwave Ovens
Cda oven is letting out cold instead of heat what should I do/
    Top Expert:
  • 12,223 Answers
Test this steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#2#ixzz2aavZv5Dh
Posted on Jul 31, 2013
Cda oven cold not hot
fix it .God bless you
Jul 30, 2013 | CDA Microwave Ovens
CDA MC41 Light not working
see this causes and fix it. God bless you
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.
Oct 10, 2012 | Microwave Ovens
MY LG microwave oven model no MH6344W does not heat the food .The oven is fine after 1 minute microwaving if i remove the food it is as cold as it was. What would be the reason please explain. I tried...
If the food is not being heated it means the magnetron is not working. The magnetron is the device which generates microwaves which heat the food. It could be the magnetron itself which is faulty or it could be one or 2 other components causing the magnetron not to work. You will have to take your microwave oven to a service center to determine the exact cause & get a repair quotation.
Let me know if you need further assistance.
Best wishes,
Graeme
Mar 17, 2011 | Microwave Ovens
My cda microwave is not heating. The lights come on and the plate turns but nothing gets heated
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 09, 2010 | CDA CM1 Microwave Oven
Whirlpool Microwave 20C turnable plate not turning,not heating
Basic
heatman101
[]\[\]0-
Nov 24, 2010 | CDA CM1 Microwave Oven
CDA CM3SS fitted everythiong works except the
There are two possibilities. Either the magnetron and its accompanying transformer has failed or it could simply be the fuse that feeds the magnetron. This should be checked by someone that is familiar with the correct servicing techniques as there are some very high power components in this area that can be quite dangerous. But if it is just the 'high tension' fuse then at least the bill wont be too high !
Jul 04, 2009 | CDA Microwave Ovens
Power but no heat
If you have no power in the microwave, check to see if the outlet is good by plugging something else into it. If there is power, you may have blown the internal thermal fuse, or the door switch may be defective. Either of these will keep your microwave from working. The thermal fuse protects both you and the oven by blowing if there is too much power going through it. When a fuse blows, it means that the wire inside that conducts electricity has broken, usually because of an electrical overload. When it blows, you need to have a professional microwave repair person replace it. If this is not the problem, it may be that your door switch has become defective. If the door switch isn't working properly, it won't let the circuit complete to operate microwave components.
Feb 19, 2009 | CDA Microwave Ovens
Microwave oven is heating cold.. instead of hot. the clock still works though
It sounds like a problem with the transformer/Magnetron section of your unit. If the unit is in warranty call the manufacturers customer care. If not, replace the oven as service is more expensive than a new unit. Ther are many great features on the new ovens and the prices are very reasonable.
Ray
Dec 15, 2008 | Microwave Ovens
Not heating properly
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't do it, and your line voltage is right, then I would say your magnetron is dying.
Slow is heat is a typical symptom of magnetron failure.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 21, 2008 | LG LMV2055ST Microwave Oven
Microwave Ovens Logo
57 people viewed this question
Top CDA Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
acmservice
Are you a CDA Microwave Oven Expert? Answer questions, earn points and help others
