Question about CDA Microwave Ovens
Cda oven cold not hot - CDA Microwave Ovens
    Top Expert:
  • 12,223 Answers
Fix it .God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#2#ixzz2aavZv5Dh
Posted on Jul 31, 2013
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
Cda oven is letting out cold instead of heat what should I do/
test this steps and fix it. God bless you
Jul 30, 2013 | CDA Microwave Ovens
CDA MC41 Light not working
see this causes and fix it. God bless you
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.
Oct 10, 2012 | Microwave Ovens
My cda fan asasisted oven is making a loud groaning noise
This should be checked out for safety reasons to avoid more serious issues. It could be a faulty turntable, power transformer, or magnetron to name a few.
Mar 06, 2012 | Microwave Ovens
My cda microwave is not heating. The lights come on and the plate turns but nothing gets heated
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 09, 2010 | CDA CM1 Microwave Oven
Whirlpool Microwave 20C turnable plate not turning,not heating
Basic
heatman101
[]\[\]0-
Nov 24, 2010 | CDA CM1 Microwave Oven
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Turnable plate not turning
turn table motor sound like.
Sep 14, 2009 | CDA CM1 Microwave Oven
CDA CM3SS fitted everythiong works except the
There are two possibilities. Either the magnetron and its accompanying transformer has failed or it could simply be the fuse that feeds the magnetron. This should be checked by someone that is familiar with the correct servicing techniques as there are some very high power components in this area that can be quite dangerous. But if it is just the 'high tension' fuse then at least the bill wont be too high !
Jul 04, 2009 | CDA Microwave Ovens
Microwave Ovens Logo
50 people viewed this question
Top CDA Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
acmservice
Are you a CDA Microwave Oven Expert? Answer questions, earn points and help others
