Top loading automatic washing machine not filling
I have a top loading automatic washer, more than 10yrs old, worked well until today, then water filling in spurts not continuously What could be the problem
  • 2 more comments
  • fescat Sep 01, 2007
    Already checked these and still doing this. It now just clicks continuously when power switched on. It's a Fisher and Paykel product and been most reliable.
  • Anonymous Mar 08, 2008
    My washer is less than 3 yrs old. It has worked great till today. It did not fill all the way before it started agitating. I turned it off and reset the cycle and it would not fill at all. If I leave it on it will click back and forth from trying to fill to agitating. I unplugged from power then plugged back in and now it will not do anything at all.
  • Jazzie0o Jan 24, 2009
    My washing machine also has the problem of not working at all. I started it, and when it was filled with water is completely stopped. The power light isn't even on. Anything I can do without expert help?
  • Anonymous Mar 31, 2009
    washing mechine is not automatically filled by water
  • 3 Answers
Pls change the water presure sensorn switch
Posted on Nov 29, 2008
  • 641 Answers
Check the filters on both sides of the inlet water line. Let me know with your results for further assistance if will be needed. Good luck!
Posted on Aug 31, 2007
  • Dov Dror Sep 03, 2007
    check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
    If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
    Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
    Good luck
Machine is not spinning
check the carbon brushes in the motor or the belt.if its not these then it may be a timer fault see if you have power to the motor
Jun 02, 2010 | Bosch Axxis WFL 2060 Front Load Washer
If you open lid during operation, washer fills all the way to top
if you really want to see, simply stick an object (like flathead screwdriver) into the little hole that the lid presses into to click the switch, hold it there
Aug 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My washer won't fill up with water...it is about 7 years old. The water acts like it is filling up but just keeps pouring water in and out.
it is problem it is just aweak inlet pressur so check inlet water from start path from wall untill the inlet filter >
good work !
thanks
Jul 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
567 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
