Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Wan't take on water after first rinse - Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
See this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Posted on Jul 31, 2013
Hobart SR24H dishwasher after rinse cycle the same time pampas water in and out of the dishwasher, two pipes are opened and working
Hello.
As per my personal opinion this is normal because for the final rinse you have a small booster or boiler..
When you turn on the machine..it starts fill and also the booster for the final rinse.
You start the machine..wash cycle...rinse cycle..
Now..new water(from rinse booster) is coming on the tank in order to rinse the dishes..on the same time the machine drains the excces water from the rinse(over flowing) and fills up the booster with new water.
Should be like this
Good luck
Jun 29, 2013 | Dishwashers
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
Water level on rinse is to low, on wash cycle the water level is good, I think maybe three quarts of water come in for the rinse cycle, please help. brand new admiral model # ATW4475XQ
this machine has a water level switch for the wash cycle and a switch for the rinse ccycle. remove control panel and take a small screwdriver and rotate the lever on the rinse cycle switch 1 click. (the rinse cycle switch is the one that does not have the knob on it. Unplug the machine before this is done. You will now have a full tub of water for the rinse cycle.
Jul 24, 2011 | Admiral Washing Machines
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
NO WATER INTAKE WHILE RINSE OPTION IS ON
It sound like the cold water inlet valve is faulty, the rinse cycle uses only cold water, and the water in the 'wash' cycle is probably hot.You need a new inlet valve, which on your machine is probably a double hot/cold unit.If you can't get a new inlet valve, a handyman/electrician may be able to change the wiring to use the 'hot' inlet valve for cold water which will allow the machine to wash, and rinse, using cold water through the hot valve..Tikka?...Good luck...Nomess
Jun 01, 2010 | LG WFT1071TP Top Load Washer
Engine will not start when the water is on. You can start the engine and then turn the water on but it will kill the engine. I have tried to clean the unloader valve.
To isolate whether or not the unloader valve is still stuck or sticking, try starting the unit with the wan trigger engaged water coming out to spray. If the unit runs while wan trigger is engaged and shut down when released your unloader valve isn't working. Hope this helps God Bless
Sep 18, 2009 | Garden
Rinse solution stays on the glasses
First chech the machine is warming the rinse water and not rinsing in cold water then have your chemical guy come and check that the soap/rinse ad dispenser is not dispensing too much rinse aid and naturally make sure the machine is in fact ricing with water I have had it where a glass washer takes more rinse aid then i should and does not actually rinse with clean watr it was simply spraying the rinse aid wich sounded as if it was rinsing soulution was new pc board it was not changeing programs properly if you have and older machine it proberly has a timer this too can be a cuase of the problm if it is not clicking over to allow a full rinse cycle.Hope this helps let us know.
Jan 17, 2009 | Hobart 29 in. AM15-1 Free-Standing...
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
109 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
