Question about Motorola Computers & Internet
Calibrate screen Not reading all barcodes, I need to re-calibrate the scanner
  • Official Brand Answer
  • 3,100 Answers
Hi
Contact Motorola Solutions Get Support or Zebra Technologies Support Downloads
Mark
Motorola Mobility Support
Posted on Jan 17, 2015
SOURCE: Symbol LS-9100-4008A
Hi I'm trying to find keyboard wedge Configuration to re-program my scanner
It's a symbol LS-9100-400BA and connections if you can fax to 1-956-546-8752
Posted on Dec 08, 2007
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
SOURCE: DS6708 symbol scanner freezes keyboard
Have you tried taking the battery out of the scanner and then reinserting it? THis should reset the scanner to some degree.
It really depends which barcodes you scanned in the manual.
Your best chance seems to be a reset to the original settings, for which you may need to look at the manual.
Posted on Mar 18, 2008
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: can't use scanner
You will need to download an application from www.symbol.com called DATAWEDGE. It is free and very easy to use. This application will enable you to scan on to any other application on your MC70.
Posted on Apr 23, 2009
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
I need to know how to clear and format to new out of the box it is a MC3090 motorola Symbol because it doesn't have enough memory and it doesn't save many codes thank you
1. Press and simultaneously hold the 1, 9 and Power keys. Do not hold down any other keys or buttons. As the mobile computer
initializes, the Symbol splash window appears for about a minute.
2. Calibrate the touch screen. See Calibration Screen to calibrate the mobile computer screen.
Hope this helps,
Ben
Sep 12, 2011 | Computers & Internet
The align screen for MC9090 is not calibrate. Already calibrate but still the touch screen is not proper.
Hi you need a replacement digitizer. The unit may have been dropped hence the reason it is now faulty. please contact jack@codeo.co.uk for repair. 00441179064587
Aug 05, 2011 | Symbol MC9090-G Barcode Scanner
Touch screen not working
try taking it in and getting it calibrated. if that doesnt work its something wrong with the sensors and they arent picking up on your touch
Jun 01, 2009 | LXE MX6 Portable Terminal
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
Align Screen
It will need a new screen. This is a common fault on this type of terminal and since the touch pannel is incorporater on the screen assembly, that is the only solution.
You could always try a software update from IPL mode, however is not very likely that it will resolve the calibration issue.
Jul 23, 2008 | Symbol PPT 8800 Wireless Barcode Scanner
Aug 28, 2007 | Symbol LS9100 Hands Free
Computers & Internet Logo
102 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
