Question about Fuji FCR 5000 PLUS CR
Have Fuji fcr5000 ma plus machine and it is showing an error drive shaft grip error called 03c6
I have a Metabo KHE-D24 with a SDS plus key less chuck, how do you remove this style of chuck?
Look at the drive shaft under the base of the chuck and look for flats on the shaft or a nut. Hold this and use a pair of multi grips on the chuck to unscrew it from the shaft. Or place a bolt in the jaws if they still work and place the bolt in a vice and undo the shaft off the chuck
Apr 29, 2012 | Metabo Khe D24 1" Sds Rotary Hammer W/Roto...
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
I have the TS-380 plus; I press on the foot to get the machine to sew, but the machine doesn't sew, it just seems to "rev" but nothing happens. Your suggestions? Thank you!
Locate the motor on the back of the machine and check the drive belt. Check the tension. if this is ok check to see if the motoe pulley has come loose on the motor shaft. If this is the case you will need to tighten the screw in the pulley to make it grip the shaft. Hope that is of help.
Aug 09, 2010 | Singer Tiny Serger TS380
Wats the meaning E00602-0003
Call the serves and must support you
or cheak un cannon site what the error
Dec 15, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Fuji plus monitor
Larry,
Try your Fujiplus monitor on another pc see if it still have the same problems. If not, then your Macbook it the caused. You say, you replaced a new hard drive? Did you formatted and reinstalled the Mac software? If not, of course you will got a blue light...cuz the new drive had nothing in it.
Good lucks!
Sep 30, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Can't take pictures with my camera
If it's showing an "E", then the film is not uptaking properly, even though it may be advancing. Try reloading the film, or, if for example you're shooting Fuji film, try switching to Kodak, or another brand. Mine will show an "E" for Fuji alomost consistently, but not with Kodak.
Dec 30, 2007 | Olympus SuperZoom 115 QD 35mm Point and...
Fuji FCR 5000 PLUS CR Logo
44 people viewed this question
Top Fuji Computers & Internet Experts
Computer Links
Victorman
Victorman
robert
Are you a Fuji Computer and Internet Expert? Answer questions, earn points and help others
