Question about Kyocera Km-1820 Copier Fax Machine
Can not receive or send fax from our fs 1128mfp
3 Suggested Answers
SOURCE: WHERE IS WASTE TONER IN
Inside the drum unit.
To get the drum unit out, you need to first remove the developer unit (which the toner is installed inside) then look inside the printer and put your fingers inside and pull the two green loops out.
Onc you've got it out, look for the side which has a silver sticker on. IF you use a flat headed screwdriver where one of the arrows points to a grey sponge, you will be able to lever off the cap and then empty the waste toner.
This is a mucky job.
Kerridge0
Posted on Dec 06, 2010
  • 29 Answers
SOURCE: "remove original from document processor"
Sensor in feeder is probably broken. To get around this until you can get it fixed power down the unit and unplug it. Unplug the cable that connects the Doc feeder (in the back) to the main unit (two screws hold it on. Then power the unit back up it will work with out the Doc feeder. You will just have to put the copies on the main glass.
Posted on Jul 14, 2011
How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
www.voipmechanic.com/voip-fax-settings-9600-baud.htm
How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
Faxing over VoIP, the correct configuration settings that you ...
www.voipmechanic.com/faxingissuesandotherdevices.htm
How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
Dell VoIP Fax Settings, how to lower the BAUD rate and ...
www.voipmechanic.com/voip-fax-settings-dell.htm
VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
Faxing over VoIP - Sfax
Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
Instructions required to replace the maintence kit
Please advise machine make/model.
You may also need to know how to reset counter
after fitting.
Jul 24, 2015 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Error type: connect
smb scanning? check to make sure host ip is conrrect as well as long in info and path to folder /email make sure smtp server address is correct along with login info and try port 587 if its set on 25 comcast tends to block 25 for smtp scanning
Jul 09, 2014 | Kyocera FS-1128MFP FS-1128MFP...
Kyocera FS-1128MFP C4000
lsu (laser scanner unit) failure or main board
Jun 30, 2014 | Kyocera FS-1128MFP FS-1128MFP...
Drum make a noice
unfortunately I don't think there is a way to fix the noise from the drum other then replacement if the machine is under warrenty rma the drum
May 28, 2014 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
How do I print double sided with this copier
pick print on both sides (flip long edge or flip short edge) in the print driver. go to kyocera support to download latest kx driver if the options are not found in your current driver
Apr 04, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Kyocera Km-1820 Copier Fax Machine Logo
57 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
