Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet front load washer is giving a F21 error code. It will not drain. When I blow into the drain hose on the back of the washer it will start draining. But everytime I run a new cycle it will do the same thing. Runs ok until it starts to drain. I've check for blockages in the drain hose and in the drain pump.
  • Whirlpool Master
  • 744 Answers
Whirlpool duet front load washer this video is on a bosch but it will help you Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
JULIANFIX
  • 975 Answers
SOURCE: whirlpool duet will not drain, F21 error code
YOUR "DRAIN MOTOR PUMP" is clogged with all that rubber particules, if your handy with tools , you can fix this one , open the washer , locate the MOTOR PUMP , (just follow where the drain hose is connected), remove , inspect and clean all the debris and lints and stuff collected , replaced and youre good to go , AJ
Posted on May 18, 2009
jsrock516
  • 5911 Answers
SOURCE: F21 on Whirlpool front load duet washer
"F21" is a Long Drain error code. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
Posted on Jun 12, 2009
  • 662 Answers
SOURCE: Duet Sport Whirlpool front loading washer is
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
blueextc3221
  • 15935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 21, 2010
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Error code f21
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Apr 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool washer is not finishing the cycle and gives an error code of F21 at the end of the cycle can you tell me what this is? tks Phil
Kevin
Mar 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When I wash a load on NORMAL, it shows a code of F21 before the entire washing process is finished. What is F21?
Kevin
Feb 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet washer gives an F21 code error and will not drain or spin. The hose seems to be clear. Is there anything I can do?
Foreign objects in the drain prestrainer :
remove front access panel below the door (3-4 screws at the bottom of the panel in front)
have towels ready there will be water. may even need a bucket depending how much back up you have.
remove round plug turning counterclockwise
remove debris and clear prepump area
check that the pump entrance is clear as well
re-assemble
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet will not drain, F21 error code
May 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
105 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
