Question about Sony VAIO PCV-RX370DS PC Desktop
When pc is star windows is slow respond and touch patch also then i am pressing any of the key pc is working normally
    Novelist:
  • 288 Answers
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Posted on Nov 13, 2013
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Touch Panel Adjustment
Functions • To adjust the position of the Touch Panel display
Use
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
Adjustment
Procedure
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
My calculator is extremely slow and i cant fix it
Here is for you. From the TI Knowledge base.
Why does my TI-84 Plus or TI-89 Titanium respond slowly to key press entries?
Issue/Symptom: When making key press entries, the product responds slowly
If a piece foreign material such as a pencil lead is lodged in the I/O port of the calculator, it may create a short causing the calculator to respond slowly to key press entries.
If the piece of conductive material can be removed, it may restore the calculator to normal operating condition.
If the material cannot be removed, contact TI-Cares Customer Support to proceed with an out of warranty product replacement.
If conductive material is not lodged in the I/O port and the calculator responds slowly to key press entries, contact TI-Cares Customer Support for further troubleshooting and resolution.
Sep 08, 2011 | Texas Instruments TI-84 Plus Silver...
Samsung s5233 touch screen not working
There is a simple answer to this and that is to replace the phones digitizer or touch screen and your problem solved.
br,
www.phonefreedomjamaica.net
Apr 11, 2010 | Samsung Star GT-S5233 Cell Phone
Touch screen shows images but doesn't respond to touch
It is most common problem with this handy cam. just get the patch cord replaced at ant sony centre. it is not that expensive.
Kumar
Apr 21, 2008 | Sony Handycam DCR-HC42E Mini DV Digital...
Game patchs
do you mean the sims 1 or 2?
well, you can run either one of them in compatibility mode, rightclick the exe or shortcut, press options, press compatibility (if i'm right, my pc is in another language) and choose windows XP service pack 2
good luck
Apr 13, 2008 | Microsoft Windows Vista Ultimate Edition
Mouse touch pad
I couldn't find an answer online, I have a Toshiba satellite with Vista and the clicking wasn't working on the pad. I found the answer....
open control panel...
hardware and sound....
mouse....
the tab Device Settings
click Settings
click Tapping on the left
click the check box enable tapping
and for everyone with problems with nothing working on the pad at all hold down the FN key next to the control key and press F9
Feb 05, 2008 | Acer Aspire 3000 Notebook
Sony VAIO PCV-RX370DS PC Desktop Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
