Question about Panasonic NV-GS400 Camcorder
Panasonic NV GS 400 mainboard problem
When I connect the DV outlet of the camcorder to the DV inlet of a DVD recorder the camera is not recognised by the recorder .Cables have been tested + DVD recorder and both are OK .The technician says the mainboard needs to be replaced to fix this problem @ 50% of what the camera cost me to purchase initially = expensive. It is out of warranty . I am worried that it is a simple soldering problem that could be fixed easily and cheaply but the panasonic policy is to just replace the entire motherboard at significant cost to the user . Any thoughts ?
  • swagener Aug 31, 2007
    Thanks Silverdragon,
    That makes a lot more sense to me now . The camera has an S-video outlet so I could probably use that .
    thanks,
    Scott
  • Anonymous Feb 12, 2008
    CAPTURE DRIVER FOR A PANASONIC DV CORDERCAM
    NV - GS400
Dude, simply connect usb wire to usb port. down load vedio editor version 8 on ur desk top (that software detects camra through usb 2.0). then go to cap option and cap recording do not use fire wire port (dv port)
Posted on Sep 10, 2009
  • Panasonic Master
  • 12,061 Answers
What he probably means is that the IC that "Drives" the "Port' has been damaged or destroyed, a very common problem. Due to the manufacturing method, IE: Surface mount compnentry, there simply aint no "Simple Soldering problem" fix, at all... the actual IC, must be replaced... but this isn't actually possible..(well technicaly it is possible, but real hard to do) so hence the only other "Fix", a board replacement. Although ya DV outlet is kaput... If there is another output? say an A/V out? could you not use that as a work arround?
Posted on Aug 31, 2007
Connect my NV-GS17EB to a computer?
Do you have DVD recorder? DVD-RW is re-writable
plug the camera up to tv and record it to dvd-rw (yes time consuming depend on the lenght of the cassettes)
now take the DVD-rw, drop it in pc (movie folder..this is real quick process)
next cassette to be recorded.
hope this is helpful
Apr 20, 2010 | Panasonic NV-GS17 Mini DV Digital...
Cant view the film after recording it.
Try uploading the video on to you pc. if you cant view it once it is on your pc then you will have to check the settings on the cam
Dec 01, 2009 | Panasonic NV-GS15 Mini DV Digital...
Required USB Driver for mini dv Panasonic NV gs 15
The Panasonic NV gs 15 can only be used as a webcam with the USB cable.
You need a 1394 firewire / DV cable to transfer the video to your pc.
May 06, 2009 | Panasonic NV-GS15 Mini DV Digital...
Free Software Download from Net
Where can I download the software for PANASONIC NV-GS 27 for capturing the Videos From the DV Cam Cassette...Because without the driver either XP or Vista doesnt recogonise the Camera..So please do the need full. Tell me where I can download the Driver for the Same..
With Regards .....Sreel
Oct 27, 2008 | Panasonic NV-GS27 Mini DV Digital...
Panasonic NV gs 27 Vista Support
Vista is notorious for not recognizing firewire unfortunately. Here is a link to a Microsoft Knowledge Base article that should help your situation. Hope this helps. Good luck.
Microsoft's firewire solution
Oct 18, 2008 | Panasonic NV-GS27 Mini DV Digital...
How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
Aug 24, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
Conversion to CD
I have NV GS 47 video camera. Earlier I used to connect it to computer and write to CD. Now the computer is not even recognising it when connected. I bought a DV data streaming cable. That also is not working. Please help me Baig
Jul 09, 2008 | Panasonic NV-GS47 Camcorder
PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
May 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
Recording Video onto the computer
HI
my comcorder Panasonic NV-GS15 Mini DV Digital Camcorder
display in the monitor " F26"
my help plaese
Mar 11, 2008 | Panasonic NV-GS15 Mini DV Digital...
Can not get the camcorder to play on computer
more details needed.
-what is the model of your DVD recorder - did you select the DV input? perhaps that model has a DV connection proprietary to it's own camcorders. Panasonic does this on many models of their DVD recorders.
-on the computer, how are you attempting to access the camera once connected?
Mar 06, 2008 | Panasonic NV-GS30 Mini DV Digital...
Panasonic NV-GS400 Camcorder Logo
648 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
