Question about Kodak EASYSHARE M1063 Digital Camera
Battery dies quickly when not plugged into a power source. Purchased new battery with same result.
  • 44 Answers
Please check if your battery is coded or not, If it is a coded battery, the inside of battery needs power to keep it. The "coded battery" is apply to some camera brand, such as Panasonic.
You should charge the battery very month to keep its life.
Posted on Oct 08, 2013
The battery does not charge anymore
Usually, the battery life can (quickly) decrease if your GPS is always plugged into a power source (even when not in use).
Like all such (lithium) batteries, to keep the battery healthy, it's better to charge it fully, then use / deplete it fully (while not plugged into a power source) and repeat the charge cycle.
If your battery doesn't charge anymore, you'll just have to use the GPS while it is plugged in. If that is even not possible (because the device actually use the battery to power it, and not the direct current from the charger), you may want to consider replacing the battery. Or, replace your GPS.
Aug 28, 2013 | Tomtom One XL GPS Receiver
The old battery will not hold a charge when not plugged in so i bought a new battery. the battery came today in the mail and says "plugged in, not charging" and the battery light on the front is...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
Battery dies within 24 hours
Hi, what makes the phone battery to die to quickly, is because the battery cell to weak and almost damaged completely and it's unable to power the phone for too long.
The battery cell is damaged.So you will need to replace the battery with a new battery.
You can go to any phone store around your area and get a new battery to replace the old battery.
When a new battery is is purchased, usually comes with a factory battery life whic is not yet fully charged.You will need to charge the battery for longer hour before use.
After purchasing a new battery, make sure you take time out to charge the battery properly for about 4 to 6 hour before use,otherwise battery cell can go flat again in no time.
Hope that helped.
Thanks for using fixya...
Jan 16, 2011 | Samsung Convoy Cell Phone
Installed new baterry and new alternator...battery or alternator dies in one day
the alternator will not die in one day unless there is a direct short causing diode or coil winding failure which would give signs of smell, melted wires. Disconnect battery and give full charge. what year is this? while vehicle is running you should be able to briefly disconnect positive battery post connection and vehicle will still run if alternator is good. For a new battery to die in one day, one of two things i think has happened. Either the batt is faulty from supplier,( not likely but i have seen it ) or there is a direct draw or grounding taking place whether its direct in the starter selonoid or a direct draw through accessories. Are you sure all switches are off ? Push switches (on interior lights) nothing like dome lights,delayed lights are staying on! Does vehicle start hard like it almost needs a jump. If it has to be (and it takes time). to find out what is drawing the power ( i am old school) disconnect positive power source on batt. 2) disconnect ignition power source on starter. 3) connect pos batt wire to starter, 4) touch positive cable to positive batt post and look for spark or contact. if this reacts then selonoid or starter motor is shorted drawing the current. Or if you have volt meter and know how to use it, this is good to. If checks good then hook ignition connection back on starter.(disconnect pos terminal on batt prior to re-connect) I think the battery is having the life sucked out of it by a short in the system ( A DRAW ) this could be a quick find or fix or this could take days to track down. alot of variables here to try to explain. but i would seek into the starter first as usually this drains the battery quickly .
Jan 13, 2011 | GMC K1500 Cars & Trucks
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
My power supply for my Presario V6000 died due to broken wires. The battery powered the computer until it died. Now, the new adapter will not power the computer.
This is a common eevnt the battery get so flat that the adapter will not charge it quickly.. You need to leave it totally alone for at least 8 - 12 hours... To see if the adapter actually works and PC is good, take OUT the battery, and plug IN the PSU, the PC will work, sans battery just on PSU. If OK, then charge up as related. It will do it after a ling time.. Sometimes batteries go so flat they are ruined, sa a new one may have to be gotten IF it does NOT charge up.
Mar 11, 2010 | HP Compaq Presario V6000T PC Notebook
Computer dies FAST when unplugged even though power may register 100% befor unplugging also laptop does not seem to recognize battery properly . battery power goes from 100% to 35% overnight if unplug
You have a dead battery or the charging circuit is faulty. If you have had the battery since you purchased the laptop, then it is worn out and needs to be replaced.
Apr 23, 2009 | IBM ThinkPad A31 Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Battery will not charge
I completely disassemble my laptop down to only the motherboard. I put everything back together and for the past few week all seems fine.
Jul 23, 2008 | Toshiba Satellite A135-S4527 Notebook
Car not starting
I think that the keys are constantly sending out signals so the battery dies fairly quickly. The good news is that it takes a standard CR2032 battery that can be purchased anywhere, and that replacing the battery is a pretty simple thing to do.
I just purchased one of these from a rental company and the first thing I had to do was replace the battery.
Jun 08, 2008 | 2008 Nissan Altima Hybrid
Kodak EASYSHARE M1063 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
