Question about Hamilton Beach BrewStation 47214 Coffee Maker
My programmer for Time is not holding - Hamilton Beach BrewStation 47214 Coffee Maker
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
My display has the wrench icon and the time icon and it says "OFF" on the display on the dash. What does this mean? and how do i get it off?
Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
May 08, 2014 | Polaris 2007 Sportsman 700 EFI
My nespresso machine stops long before it should.
Most Nespressos that I have worked on have an auto programme function. Put the pod in and a cup under it, press AND HOLD the button down until desired quantity is in the cup. Release the button, that should programme it to deliver that same quantity next time.
Oct 17, 2013 | Coffee Makers & Espresso Machines
Can I turn the beeper off on the end of the washcycle on the DDY062 Hoover dishwasher. I want to put it on timer delay and dont want to be woken in the middle of the night.
These are the instructions taken directly from the DDY062 manual:
Alarm mute for the PROGRAMME END
The alarm for the programme end may be muted as follows:
IMPORTANT The dishwasher must be ALWAYS off before start this procedure.
1. Hold down the "PROGRAMME SELECTION" button and at the same time switch on the dishwasher by pressing the "ON/OFF" button (a brief audible signal will sound).
2. Keep the "PROGRAMME SELECTION" button pressed for at least 15 seconds (during this time, 2 audible signals will sound).
3. Release the button when the second audible signal sounds (3 "PROGRAMME SELECTION" indicator lights will come on).
4. Press the same button again: the 3 indicator lights (which indicate that the alarm is activated) will start flashing (to indicate that the alarm is off).
5. Turn off the dishwasher by pressing the "ON/OFF" button to confirm the new setting.
To turn the alarm on again, follow the same procedure.
Jun 21, 2012 | Hoover Dishwashers
I keep setting my thermostat but it automatically goes back to same temperature no matter what i set it at
If it is a programmable thermostat, it will only stay at a certain temp until it reaches it or on a set time, then it goes back to the scheduled program temperatures. Most programmable thermostats do have a hold feature that allows you to hold the temp to a certain setting, but if you don't set it to permanent hold, then it does what you described. Hopefully this helps some or guides you in the right direction. Good luck!
Mar 12, 2010 | Heating & Cooling
Hotpoint aquarius
You need to hold the start button infor at least 3 seconds, then change programme to pump out. once that programme has finished change the programme to what you want.
Oct 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed...
It is the childproof lock that has been set, to clear it you need to set machine as you would normally to start a programme but hold the START/PAUSE button for 5 seconds, that will clear it, remember that is also the way to put the lock on again so I would advise not holding the start button down too long.
Jul 31, 2008 | Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
22 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
