Question about Ricoh Aficio SP C820DN - Printer - color - duplex - laser
My printer is showing SC852, what do i do? and what could have caused the problem?
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
Show error cod c3100
Hi Shanzia-
You don't say what make/model of your printer is. Try going on their website and see if they have a troubleshooting chapter. They likely have a section where their error codes, their causes and solutions are listed.
Apr 01, 2014 | Office Equipment & Supplies
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
Error lost cpu rest
This error on the T6125 may be caused by either a hardware fault with the printer, alternatively the problem may be caused by some sort of external influence on the printer. Passable resolution to the problem include;
Hardware Fault
Locate the main logic board, check the CPU to ensure all pins are soldered correctly on the PCB. Check there is no solder over spill shorting any of the pins.
There may be a fault with the main logic board which may require replacement.
External Influence
1) External Print Server
One of the most common causes for the LOST CPU error is the use of external print servers connected to the Parallel Interface.
These printers are not reliable if connected to external print servers unless the printer parallel interface has been set Uni-Directional. To do this, you need to follow these instructions.
Set the printer to Offline.
Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On)
Press the Mode key: display will show Offline Normal.
Press any Arrow key until display shows Offline Config.
Press the Forms/1 key.
Press any Arrow key until display shows Config Parallel.
Press the CPI/2 key.
Press any Arrow key until display shows Parallel Bi-Dir.
Press the LPI/3 key.
Press any Arrow key until display shows Bi-Dir Off.
Press the Enter key and the interface will be set.
Press the Clear key.
Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off)
On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Electrical Interference
Check the area around the printer to ensure there is no external electrical interference eg Electric Motors, High Voltage Cables in near vicinity of the printer.
Feb 21, 2011 | Tally T6215 Matrix Printer
Paper is not jaam but printer showing paper jaam again & again.
Several things can cause a jam. I can suggest checking the paper path very well, especially if you have had a jam in the past, a little piece of paper there could be triggering a sensor and causing the message. Another thing might be rollers worn out or dirty. If the rollers rotate 3 times and no pick up happen it will show paper jam, try a humid tissue to clean it.
Sep 07, 2010 | HP Officejet 4355 All-In-One InkJet...
Printer shows error 1200. how do I fix?
The error 1200 is caused by the cartridge carrier getting stalled. That can be due to several causes. Here's an article in the Lexmark website to guide you to identify and, hopefully, resolve the problem. Just click on this link: http://bit.ly/9QxkWP. Hope this helps. If you need more assistance, place a comment so I can get back to this. Thanks.
Apr 13, 2010 | Lexmark X4270 All-In-One InkJet Printer
Printer stopped working. pc sending job to
hhhmmm... maybe you have installed the drivers many times.. the printer shows more copies in the printer panel... you must delete those printers... because that will cause conflict ....
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Printer will not function fron computor . I shows than it shows error.
Hello my friend, regarding on your problem try to check the connection of your printer if it is properly connected. Then try also to check if that printer is online and installed properly cause the main reason why printer won't work is either the connection is not properly connect or printer driver not installed properly.
Jun 16, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Reseting mp210
i've refilled mp210 both cartridges.do you know how to reset the printer?cause it's show error 6,please help
Mar 30, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Ricoh Aficio SP C820DN - Printer - color - duplex - laser Logo
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
