Question about Garden
The drive belt on my Honda HRT broke. I replaced it and within a few seconds the new belt broke. I know the blades are turning, but I'm wondering if the wheel on the transmission is not turning thus the belt is being shredded. How can you test if the transmission is working properly? I do know that after replacing the belt and getting the mower started I engaged the drive handle but the rear wheels never turned.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Could be rear end is locked up you will have to get another belt try turning wheels by hand if loose see if there are broken bearings anywhere on the drive usally thats the case with the belt bearing goes out and shreds thr belt try those ideals
Posted on Jun 07, 2014
SOURCE: Wheels do not freely roll backwards
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
SOURCE: I have a Honda HRT216SDA lawn mower. I replaced
Took it to a repair shop.
Posted on Sep 03, 2009
vincob
  • 718 Answers
SOURCE: Blade won't stay engauged
It is very hard to say without knowing model, but if it is a Honda Harmony than I would look towards the the cable that controls the blade engagement. If your model is equipped with a blade engagement lever most likely yours is controlled by a cable also and it only needs to be adjusted correctly. Good luck!
Posted on Oct 22, 2009
SOURCE: how do I replace the clutch cable on my honda self
I fixed the drive cable just yesterday. If the model is exactly hrx217hxa with the serial number between MAGA–1000001 and 139999 as mine is, it can be quite involved to replace the cable if this is the first time, because honda wants to replace the "control arm" as well. You can find a detailed instruction to replace the drive cable from the following link.
http://www.lawnsite.com/showthread.php?t=281234
The part number that you need to order is 06225-VH7-305, which comes with a very brief instruction on how to replace based on the service manual (not the user manual). The above link will guide you to how to replace the cable, but since the transmission end of the cable changed, you need to replace the "control arm" as well. This requires to disengage the drive "belt", which is the first challenge. Once you disengage it, it is relatively straight forward to replace the "control arm" if you have the right tools (1/8" pin punch and a challen lock plier which are described in the instruction that came with the cable kit).
Engaging the drive belt back on is the biggest challenge in the whole process, unless you have the right tool to handle the powerful spring that pulls the whole transmission to give friction to the drive belt. I spent two hours to try to engage the belt without the right tool (probably you need a "brake spring tool"), and I finally did it.
The rest of the assembly process is straight forward if you memorize what you did for disassembly. The above link can help you as well.
I took pictures of every step, and am going to post it somewhere soon, but if you want to replace it soon, please send me a message if you need help.
Posted on Nov 24, 2009
SOURCE: Broken rear axle on my Honda hydrostatic drive push mower
The last time I had a Honda mower in my repair shop I noticed that Honda doesnt do individual parts on its transmissions for mowers OR tillers.
You can fix this mower...but the transaxles are a bit expensive. Honda mowers do tend to be worth it though.
If the axle broke cleanly maybe someone would weld it back together?
I mean, the wheels dont turn that fast that balance would be an issue right? And I am sure the axle metal is cold rolled steel....which is to say it isnt thin cast material that would resist welding. If you take the transmission out of your mower and just take the parts to a good jobber maybe they would give it a try for 10-20 bucks? Dont expect a guarantee...but, for 20 bucks most shops wont even pick up a mower let alone try to fix it.
If this gives you another couple of years of service that would give you time to consider a replacement mower when the unit needs service again.
Good luck and be careful!
Posted on Jul 02, 2010
How do you change a drive belt
http://www.youtube.com/watch?v=XFyioOTdh5k here you go
Jun 24, 2014 | 2006 Honda Big Ruckus
I need to replace the battery in a Hrt Slim Mini heart rate pedometer.
https://www.nbmonitors.com/assets/Manuals/Archives/HRT%20Slim_HRT%20Slim%20Mini/HRT%20Slim_Slim%20Mini_English.pdf
Dec 26, 2013 | New Balance Balance Hrt Slim Mini Heart...
HONDA MOWER HRT 216 S3DA NO SPARK WITH A NEW PLUG?
Bad coil or one of the stupid safety switches isn't working properly.
I'm sorry but that VERY expensive HRT is a disaster as far as things always going wrong. The drive cable will break soon too. 2 hours labor for that beauty
Aug 23, 2013 | Garden
I recently replaced a worn blade belt on my poulan pro 42"deck riding mower. The mower is about 6 years old and has run great the whole time until the belt broke. The problem is that now the blades...
ill bet one of the blade holders has a bad bearing and doesnt spin freely. loosen the belt and check them all. some you can reoil but not all. good luck
Jun 17, 2017 | Garden
I was driving my 1991 honda accord an timing belt broke iam woorried that it might have damaged engine what should i look for i was going to replace belt an try to get back running any advice thanks
Honda engines are what they call interference engines. This means when a timing belt breaks, the pistons hit the valves and bend them. You will need to remove the cylinder head and get the bent valves replaced if you want it to run correctly. Impossible to know how many valves are bent, depends on how fast the engine was turning when the belt broke.
Aug 19, 2011 | 1992 Honda Accord
I have an older Harmony II HRT 215. The drive
the best thing to do is take the model number and order a belt from honda which will be the right size and thickness
Aug 09, 2009 | Garden
Deck belt keeps tearing up then falling off
If it's an idler pulley, where the belt changes direction from the engine - yes it should turn freely. If it's a double pulley where the drive pulley from the engine connects with the deck/blade pulley, then it it's not going to turn totally free because of the blade pulleys connected to it. But in all cases, none of the pulleys should be seized. Try using WD40 or PB Blaster on the pulley bearing surface to loosen it up - or a new pulley...
Jun 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Yard Machine posessed by devil
there are to belts the lower belt drives the blades ,the belt above it drives the mower that's mabey where your problem is.
May 23, 2009 | Garden
Belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Feb 28, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
