Paper already inserted but it still flash that error... How do i fix this issue?
Canon cp800 printer
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Press cancel then resend doc/pic
Posted on Aug 03, 2013
SOURCE: E14 error on my printer canon MP145
e5 flashing in the botton
Posted on Jan 13, 2009
  • 52 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE: Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Posted on May 03, 2010
My tray is not feeding the paper,,,,how do I fix
The pick up roller has too much paper powder on the surface. Use a Q-tip and isopropol alcohol to clean the surface of the rollers.
May 29, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Problem in setting the printer spooling of my two cp800
1-800-243-0019 Call on our Toll Free Printer Support Number and we providing best service for resolve all printer spooling of my two cp800 issues.
Apr 14, 2017 | Canon SELPHY CP800 White Compact Photo...
Error paper feed in canon Selphy cp800
LOOK 4 A BLOWER OR BRUSH CLEAN THE SENSOR. LOOK FOR WATER AND CLEAN THE ROLLER
Mar 08, 2012 | Office Equipment & Supplies
Error message: Service error 5100 on my Canon MP160 Printer
The main reason of Canon Printer error code 5100 If you receive Canon printer error code 5100 message this means you need to reset the printer. This also signifies that your computer does not recognize the printer. Your printer will show this error code because the LED is blinking. If your PC does not recognized the printer then it will also affect your printing jobs and you will not be able to do any printing work.
When the error code 5100 appears in your Canon multi functional printer then the Printer LED light will blink. This also means that you need to reset your printer. You must fix this error as quickly as possible. For instant technical support please contact Canon Printer Technical Support.
Tips to Resolve Error Code 5100
  • The Canon printer will show error code 5100 to warn the user that there is some problem.
  • In order to fix the problem, you require to opens the top of the printer.
  • In the right side of the printer you need to search for the waste ink absorber pad.
  • The next step is to clean the waste ink absorber compartment with a paper or cloth. This also completes the resetting process of the printer.
  • Inspect the paper feed area of the printer and confirm that there are no obstructions or paper jams in the printer that may be responsible for the error.
Dial our toll-free number +1-800-213-8289 for quick online assistance for resolving technical issues relating to the Canon printers. Our Canon Printer Support Number service is available for fixing technical glitches of our customers. Please get in touch with our tech support team and will receive online remote technical help at highly reasonable charges.
Our Epson printer support technicians are always ready to sort out each and every printer related issue with latest solutions offered to its clients. We are a team of fastest printer tech support solution provider for every issues related to all printers such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc. If users are unable to solve this problem, they are welcome to drop us an e-mail and we promise to get back to them in short time span via our professional printer contact details. So, come and join us for tom experience our exceptional level printer solutions to your unexpected and critical issues. And also our Canon printer technical support technicians are always ready to sort out each and every printer technical issues with instant solution. We also provide instant remote support for Brother Printer technical support services for your common printer errors such as Software installation issues, Driver Upgrade, Change Printer ink, Printer Spooler and Paper Jam issues etc.
How to Fix Error Code 5100 in Canon Multi functional Printers
Jul 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My canon IP 1880 problem paper jam but no paper ... pls help me ..
If a paper jammed inside the printer before experienced this error there might still be a small piece of paper that remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on. If you're sure that there is not even a smallest paper in the machine and you're getting this error, this might just be a glitch that can be fixed by a power reset. While the printer is ON unplug the power cable from either the back of the printer or the power outlet, leave it 20 to 30 seconds then plug it back. If the message still shows then that might already be a hardware issue. You can contact a Canon representative for additional troubleshooting. Technical support reps have special codes to reset their products to factory default should there be "glitch" issues like this. Once all the troubleshooting steps have been exhausted, that's when we can conclude it is a hardware issue that needs repair.
Apr 01, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Error 3 indicated - what is it and how do I fix it
E3 means that there is a paper jam. If you are getting the E3 error and there is not an actual paper jam you may need to do is simulate a paper jam. Try inserting paper crooked to cause a jam so that when it starts trying to feed the paper through it gets jammed. Then lift the cover up and take the paper out. You'll then get a bunch of the lights flashing. Turn the printer off and then back on and you should be good to go.
Mar 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Service Error 5100
Somtimes in order to get the printer to reset properly you must turn it off, unplug the usb (or other data cable), unplug the power cord and wait a bit. (Canon says 10mins.!).
Then reconnect cables and turn it on.
This should reset an alternate orange/green light condition.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
k24674
jasbo
jasbo
