Question about Sharp "MX-3110N Color Copier, Printer, Scanner : MX3110N"
Color printing sharp mx3110n - Sharp "MX-3110N Color Copier, Printer, Scanner : MX3110N"
Sharp mx-3110N keeps jamming
Hi Diana,
There could be a small bit of paper left behind from a previous jam that is causing the problem.
Depending on the location of the jam there are a variety of potential problems. If you could give me some info on the location I might be able to help you out.
Otherwise you will need to call a dealer to look at it.
Jun 27, 2016 | Sharp "MX-3110N Color Copier, Printer,...
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
Error code l4-06
This is a laser error code. You'll have to have someone come out and service the machine. If you're in the Houston, TX area we'd be happy to be your servicing dealer. 281-351-5128 Skelton Business Equipment Houston Copiers
Feb 27, 2014 | Sharp "MX-3110N Color Copier, Printer,...
Sharp mx-350n will not print in color from the network
Which model is it? The MX-350N is black and white, the MX-3501N is a color model. I'll assume it's the MX-3501N.
Either it's defaulted to print B&W in which case you just go to your printing preferences of the print driver in the printers menu in the control panel, and uncheck the "black and white print" box, or you have account/user codes that you need to enter in your print driver in order for it to print color. Instructions for adding a user code to the printer driver are found here.
Setup and Manage User Codes Account Control on Sharp Copier
Feb 03, 2014 | Sharp Mx-3501n Color Copier Printer...
F2-40 error code on mx3110n
black toner supply trouble, try a different toner cart, remember to shake the cart before installing. power the machine on and off, if the code is gone then it was the cart if it doesn't clear your service tech needs to see the machine.
Jan 13, 2014 | Sharp "MX-3110N Color Copier, Printer,...
How to print on transparency film on sharp ms 311ON
Firstly, make sure that you have copier safe transparencies.
Then follow the instructions below, except choose transparency instead of envelopes/labels. and make sure you choose the correct type from the print driver as well. They must match for it to pull the paper in.
How To Print on Envelopes or Labels on Sharp Printer
Dec 06, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Sharp mx 3110n, all settings are at "Plain Paper", when print a worksheet from excel, does not print because settings say "Heavy Paper"
Excel treats each worksheet as a different print job. Make sure each page is set to the type of paper that you want to print on.
Under the Page Setup make sure the type is set for the correct type, as well as in the print driver.
How To Configure Sharp Print Drivers with Installed Options to print...
Oct 21, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Wondering if you can help set up a sharp
go into printer properties and see if there is an option for color...
Dec 16, 2009 | Sharp MX-2300N Color Copier
Sharp "MX-3110N Color Copier, Printer, Scanner : MX3110N" Logo
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
