Question about Apple iPod touch
Password forgotten now say's disabled - Apple iPod touch
  • Apple Master
  • 27,725 Answers
Unlock a Disabled iPod
If you own an iPod Classic or iPod Nano, you can set a four-digit security code on your device and then lock it to keep other people from accessing it.
Disabling your iPod is a good way to protect the data on your device, but if you lose or forget the four-digit code, you will need to manually unlock it in order to access your music and other content.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC.
Open the iTunes application by using the dock icon on a Mac or the start menu on a PC.
Click on the name of your iPod under the "Devices" list in the main iTunes window.
Click on the "Sync" button to create a connection between the computer and the iPod.
Click on the eject symbol after the syncing process is complete, and then unplug your iPod from the computer.
The lock code has been reset; when you go to disable the iPod again, you will be prompted to choose a new four-digit code.
Or
Hard Reset a Disabled iPod Touch
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
http://support.apple.com/kb/HT1808iOS: Unable to update or restore
Posted on Aug 04, 2013
Forgot my phone password HUAWEI G6600
IMEI 356344043552076
SVN:78
Forgot my password and the defaults codes are not working. Pease help
Mar 31, 2013 | Huawei Unlocked G6600 Qwerty Smart Cell...
How can I reset my system password?
Disabling a Forgotten Password
If you forget the system password, you will be unable to operate the system until disabling the password. Disabling the password involves going inside the computer and changing a jumper setting (twice) on the system board.
To disable a forgotten password, perform the following steps:
  1. Turn off the system and remove the cover.
  2. Move the jumper plug on jumper A to pins 2 and 3 to disable the password(s).
  3. Turn on the computer. Powering up the system with jumper A set to the disabled position erases existing password(s). Before assigning a new system password, you must reset jumper A to the enabled position.
  4. Turn off the computer.
  5. Place a jumper plug on pins 1 and 2 of jumper A to enable the password features.
  6. Replace the computer cover.
Dec 28, 2012 | Dell Latitude E4300 Notebook
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
Bios password
if you remember BIOS password, you can disable/reset in BIOS.
if you have forgotten BIOS password, you need to remove CMOS battery and re-install it. password will be reseted. However, you should do it only, if you're good at computer hardware.
Apr 18, 2011 | Computers & Internet
Sister has forgotten password
If she cannot remember the password you can reset it. This will require a seperate computer with a CD burner and a blank CD to make a bootable disk, then simply follow the instructions on the page linked below.
Before resetting the password check the lights for your keyboard though. You may have your number lock turned on which will turn 789UIOKJLM into 7894561230 creating a number pad on your keyboard. If this is the case find the key marked "num lk" if it is the same colour as the letters pressing it should disable the number pad, if it is surrounded by a line or a different colour you will need to hold down the Fn key then press num lk to enable/disable the numberpad, you should see a light with a picture of a lock come on and off to denote number pad on or off. Ensure it is off then retry logging on with her password. If it still doesn't work, then procede to the link below and follow the instructions carefully.
http://www.watchingthenet.com/reset-windows-password-when-you-have-forgotten-it.html
Hope this helps FixYa,
Chris
May 14, 2009 | Dell Studio 17 Laptop Computer PC...
ELock password reset
one thing you can try first, is to disable the elock service from
start -> run -> type in services.msc
look for elock service right click properties startup type disabled and stop the service, on some elocks this is enought to stop it from working. but it debends I can fix this and I have done it many times now..
Dec 02, 2008 | Acer Aspire 5100 Notebook
How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
Apr 14, 2008 | Philips Magnavox 27MS343S 27" TV
Apple iPod touch Logo
203 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
