Zanussi FJ 1033 washing machine. The water in the machine overheats on 40 and 50 degree programs (not tried on others). It does complete each program.
  • dross166
    dross166 Apr 15, 2014
    Solution now found. The correct thermostat and correct circuit borad are no longer available. Washing machine given away on Freecycle. New Beko machine now in use. Thanks for the help.
  • Washing Mach... Master
  • 744 Answers
You can try changing the thermostats this video is on a bosch but it will help you
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
  • 17 Answers
SOURCE: our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Posted on Dec 17, 2008
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
  • 183 Answers
SOURCE: Flashing Lights on Ariston A1636 & Won't progress to rinse either
Suggest checking for a faulty heater. Regards Engineer
Posted on Jul 29, 2007
barkencoa
  • 3463 Answers
SOURCE: Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Posted on Feb 10, 2009
  • 109 Answers
SOURCE: washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
Posted on Jun 16, 2009
60 degree wash wont spin
Would it not take time to heat up water to 60 degree temp before it starts to spin ?
May 03, 2014 | Zanussi Washing Machines
Lavatrice zanussi zwf1415w
Switch off the machine for few minutes. Check the inlet for free flow if not clean the inlet filter, check the drain filter if there is water logging within after wash. IF not try with all the other programs and if the fault repeats, check the water level controller . If not the program controller is a suspect.
Aug 22, 2013 | Washing Machines
I have a Zanussi 1200 fj 1254 when I turn on the machine and it starts to fill with water...water starts to pour out of the fluff filter mechanism never mind how tight we try to do it up ... any ideas ??
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home completely. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | Zanussi FJ1254W Front Load Washer
My Zanussi FJ 1254W has suddenly started leaving lots of undissolved powder in the clothes after washing. I've checked that the filter is clean, and used Calgon though a couple of washes, but it hasn't...
Try filling it up with HOT water and vinegar use about 2 cups for a full load. Also take the hot and cold water hoses off the washer and check the screens for little sand like rocks that can block the water flow. I always use liquid and not the powder. Another thing is not to put the clothes in first. After you try the other things first then try to add the water first with the powder and then put the clothes in. Don't over load the clothes. This can cause the powder not to dissolve either. Hope this helps.
Dec 06, 2009 | Zanussi FJ1254W Front Load Washer
Drain pump FJ 1454W
Prob sorted, phoned Zanussi service enginneer
Nov 13, 2008 | Zanussi FJ1454W Front Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
