Question about Craftsman Garden
Craftsman riding mower model 917.28714 runs well but then starts slowing down but no loss in engine power
  • 126 Answers
SOURCE: mower backfires and loss of power
i would also check fuel flow. pull the gas line from the carb and see if gas flows out at a good rate (into a metal can of course) or if it trickles out. if the latter, then gas tank either has junk at the bottom preventing the gas from flowing or the vent hole (usually on the gas cap) is plugged.
i have also had my carb float bowl rust out on me, but that took 10 years.
Posted on Jan 29, 2009
SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
Mower runs fine until I engage the blade. it then bogs down
A couple possibles I can think of:
  • Carburetor main metering circuits are clogged. An unload engine primarily runs off the idle circuit.
  • Blown head head gasket or other loss of compression.
Mar 31, 2015 | Craftsman Garden
Power loss
sounds like the engine is running lean caused by dirty jets inside the carb
Aug 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Riding Mower (24 HP 42 in cut Model 289254) with throttle issue. Very slow in 6th gear
follow the throttle cable all the way down to the engine. Have some one move the throttle up and down to see if the throttle plate is opening and closing all the way. You can loosen the screw holding the throttle cable and move it back and forth to see if it will allow the throttle plate to open and close correctly. It may have slipped when the assembler tried to tighten it.
Mar 10, 2012 | Craftsman Garden
Riding lawnmower loss of power, runs ok at first but in 1/2 to 1 hr loss of power, replaced fuel filter/fuel kit
you need to check compression. sound to me that ether the valves need adjustments or you have cylinder damage causing compression loose when engine warms up. send me the model# of the mower and engine too.
Feb 09, 2011 | Garden
Oil leak on riding Craftsman LT2000 (Kohler)
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Jun 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn tractor lost power while in use engine slowed down
Check for spark, if spark is present, then remove air cleaner and pour some gas down carb. not to much, then keep away while starting. If motor starts and runs then shuts off you have a stuck needle and seat or fuel pump problem.Also check oil level.
Mar 06, 2010 | Craftsman Garden
  • dirty fuel filter
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower with 18.5 hp Intek Will run wide open only, regardless of throttle position. Linkage appears to be okay. Stuck float? What about the bowl electric solenoid valve?
check the lever biside the mower that connects to your carb. move it by hand while running if no change the governor has broke,, need to take engine off and replace, but if you move it and it slow down change spring
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Zts has no Power when Blades Engaged
check your blades to make sure that they are not hitting the deck,, this would cause the knocking sound
Aug 19, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
