Question about NEC PlasmaSync 61MP1 61 in. Television
NEC plasmaSync 61mp1 problems
I have a NEC plasmasyen 61mp1 that was given to me because the company was replacing it. It would do nothing when powered on. I opened the back and found one of the 15amp fused blown. I replaced the fuse and powered it up. The green light came on and the fans powered up. Then the fans stopped and the green light blinked 3 times and the red 1 time it continued this sequence. The screen stayed dark. I do not have the remote to the monitor. I tried the input button but nothing happened to the picture. The unlock is activated on the back. So I unplugged it and am asking for some thing to try. Please help. Coopersdad
  • 1 more comment
  • coopersdad Aug 31, 2007
    When I powered it up there was an arc. I couldn't find it at first. But one of the little (about 2x2) double stacked boards is fried. It plugs into the large board, I am assuming it is the mother board. The burned board looks to be glued to the back of the flat panel. I am sorry I don't have the board #s with me. I will add the image of the board this evening.
    Coopers dad
  • coopersdad Sep 01, 2007
    photo of the power supply
    board photo different angle
  • 944 Answers
Here is the link for the user manual if you need it; http://www.necdisplay.com/Documents/UserManuals/PX-61XM1A_MAN_2ed.pdf Check page 54 of the manual (61 of the pdf) right at the bottom. The lights you have indicate that either the power supply citcuit, the screen, or one or more fans have been damaged. If you are sure all the fans work, then the power supply is the only repairable posssibility. replacing the screen is not worth it. The fact that the fuse blew but doesn't blow again makes me suspect one of the transformers or capacitors in the power supply has blown, causing the short that blew the fuse, but also then melted the short so it no longer blows the fuse. If you have a multimeter, and ideally an ESR meter, with a good photo of the power supply unit we can hopefully talk you through what to check - otherwise get a repair shop to look at the power supply. Hope this helps :)
Posted on Aug 31, 2007
  • Anonymous Sep 01, 2007
    It doesn't look like there is anything on that board that can be usefully checked or replaced with normal tools. Best bet is probably to replace that board - do you have a manufacturers name and number for it - if so I can try and track you down a replacement to see if it is worth it - should be.
SOURCE:
Cannot get it to change input on NEC
You may have the child lock enabled on the front panel, visit the NEC website to download the owner's manual to your television, search the manual document for the text "child" and there should be a two button simultaneous depression to disable the child lock feature. Check eBay for a remote control if needed.
Dec 22, 2013 | NEC PlasmaSync 61MP1 61 in. Television
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
Jul 11, 2011 | NEC PlasmaSync 61MP1 61 in. Television
NEC Plasmasync 61mp1 - won't turn on
Its the power supply board. If you cant get the whole board, check your transistors theyre most likely FSXXX-X (part #). Replacing them should solve the problem. And they're only about a dollar each so youll save a bunch too but it requires a little more work.
Mar 24, 2009 | NEC PlasmaSync 42MP3 42 in. Television
61MP1 turns off after 5-10 minutes
Ryan
I have a 61MP1 that wont turn on. I get the green flashing light to signal power but nothing happens with the plasma. You seem to know a fair bit. A guy in UK said he'd supply a new power board for $500 but wants my old one in return. Sounds like it might be something I can fix here. Any suggestions. Barry
Aug 02, 2008 | NEC PlasmaSync 61MP1 61 in. Television
A Plasma TV
Sorry forgot to say ours is an NEC plasma PX42vp4g/s
Nov 18, 2007 | NEC PlasmaSync 61MP1 61 in. Television
this sounds like the engine or the lamps are bad.
Aug 31, 2007 | NEC PlasmaSync 42MP3 42 in. Television
NEC PlasmaSync 61MP1 61 in. Television Logo
564 people viewed this question
Top NEC Televison & Video Experts
Ekse
Kyle Steven OHare
Kyle Steven OHare
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
