Question about Garden
21" Troy Built Self Propelled lawnmower engine won't start.
    Master:
  • 969 Answers
Remove spark plug, clean or replace. Remove air cleaner, clean or replace. Ensure oil is full. 30w. Drain old gas out of tank. Fill with fresh gas with Stabile added. Remove bowl from bottom of carb. clean. Observe bowl screw, see if hole goes thru screw. Clean out. Bread wrapper works nice. Observe float. Float down gas flow, float up no gas flow. Re-assemble, prime 3 times, pull rope 10 times to start. No start replace carb.
Posted on May 28, 2014
landsend
  • 1066 Answers
SOURCE: Troy Bilt Self Propelled Lawnmower drive belt
belts usually come off for a few reasons.
They become loose...stretch or the tensioner moves,  Make sure that none of the tightening bolds are slipping.  You can dab them with a bit of paint.
when the pulleys are not in alignment or crooked or bent.  Eyeball the path from one pulley to another, also make sure the tensioner is in alignment and there are no other obstructions.
good, high quality belts are required, and they must be real drive belts...not regular v belts.  If there is a way to watch the belt in operation you can usually see what's going wrong.
On my lawnmower I had to grind some metal away where the belt went from the motor to the transmission.  Good luck
Posted on Apr 18, 2009
SOURCE: Troy Built 6.75 Self Propelled to Slow
You have to take off a part behind the gears and move it to a slot farther away. Mine was the same way. It's in the manual on how to adjust the speed to go faster.
Posted on May 30, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Posted on Jun 05, 2009
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
My Troy-Bilt TB330 163cc 21-inch 3-in-1 Rear Wheel Drive Self-Propelled Lawnmower will start and run for a few seconds then stops. Why
sounds like a fuel problem. check to be sure the air filter is clean. if it is you may need to take the bowl off the carburetor and clean it. or maybe even take the car off and clean really good. over time dirt or debris even water will plug up the jets inside and cause it to do what you are saying.
Apr 08, 2017 | Troy-Bilt Garden
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Why does oil and gas come out of air filter on a troy bilt model 725 ex 21 inch self propelled lawnmower.
You haven't recently had the mower on its side have you? If not you may have a valve or valve timing problem.
Aug 24, 2014 | Garden
WHERE IS THE KILL SWITCH ON A TROYBUILT SELF PROPELLED LAWNMOWER
the switch is built right into the cover over the carb , there is a cable that runs right too it from operators handle
May 13, 2014 | Troy Bilt 5.5hp Self Propelled Mower
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybilt self propelled model series 830. Yesterday we hit a stump and the blade bent and shut the lawnmower off. I recranked it and tried to recut when i noticed the blade was bent so i took it...
the blade is bent,replace it or you will ruin the engine,a new blade is much cheaper than a re-built engine and bearings,you bent it soooooo bad you can no longer even balance it, and if you continue it will destroy the engine if you have not done so already,this is the vibration you feel NOW
Jul 29, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
102 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
