Question about GE Om75p31 / Samsung Microwave Magnetron Wb27x10516
My microwave oven samsung does not heat and it has hardly been used. Our technician has said that the Magnetron OMP 75P-31 does not function
SOURCE: microwave oven problem
the most probably is the magnetron , when the capacitor is damage the equipment blown the fuse
Posted on Jul 01, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
  • 338 Answers
SOURCE: GE Microwave strats, runs, but not heating and have bad odor
there should be 4 screws holding it in.. and one plastic connector with 2 wires in it that are plugged onto the mag..
the seal would be the gold colored mesh around the antenna of the mag. when you take the microwave down you would take the cover off and if looking at it from the back you would look towards the right side and there should be a thermostat there that may have started to burn up. if it is replace it and the wires.. the mag you just unscrew remove and install the new mag.
Posted on Jan 19, 2009
beltronic205
  • 1474 Answers
SOURCE: GE Spacemaker Microwave is not heating, replaced
Check thermal fuse cut out gone..
Posted on Apr 06, 2010
heatman101
  • 43501 Answers
SOURCE: The microwave part of GE profile JVM1190
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Frigidaire microwave professional series
If its the magnatron I suggest a technician
Apr 18, 2014 | Microwave Ovens
No heat from my microwave
It's a major problem. The component that produces the microwaves has ceased to function. You may have a warranty fix available.
Nov 14, 2013 | Advent MW912BK Black Built-in Microwave...
Samsung CE245g microwave doen't heat
Either the diode most use, the large filter cap, the inverter which drives the Magnetron that does the heating or the Magnetron itself.
12_17_2012_8_04_14_pm.jpg12_17_2012_8_04_35_pm.jpgtypical diode used on left and Magnetron on right.
Dec 17, 2012 | Samsung Microwave Ovens
Doesn't heat
If the food is not being heated you will need to have the oven checked by a service center technician.
Your oven has a device called a magnetron which generates microwaves which heat the food.
It could be the magnetron itself which is faulty or another component which works alongside the magnetron.
Best wishes,
Graemevm
Mar 17, 2011 | Samsung MW4699S Microwave Oven
My samsung G2739N microwave does not function. Only the lights on the panel are on when the power is ON. please help
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days. there really is no way to fix yourself unfortunately, unless you are a technician. its bad that they dont make things like microwaves last longer, they use the cheapest parts possible and they dont last long, maybe a few years and they are no good. hope this helps, good luck to you
Jan 14, 2010 | Microwave Ovens
My convection microwave will not heat up in convection mode. the microwave function works just fine. is there a way to troubleshoot and repair the problem?
    usually if convection fails means there is problem in magnetron you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
please do rate me on the above said issue
Dec 30, 2009 | GE JVM1790SK Convection/Microwave Oven
MY MICROWAVE DOEST HEAT, IT LOOKS LIKE WORK NORMALY BUT DOESN HEAT
pull your magnetron connector out and clean the both pins with alcohols or a metal cleaner and then fix it again and use. magnetron will work surely.
Oct 03, 2009 | Samsung MW8574W Microwave Oven
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
Microwave not heating food
check magnetron and related circuit, and control unit and highvoltage section..
Nov 19, 2007 | Microwave Ovens
Repairing Sansung Microwave version CM 1029
first check voltage to hv transformer if volts probably loose contacts on magnetron ,cap ,diode if still change magnetron
Mar 18, 2007 | Bosch HMT9626GB Microwave Oven
GE Om75p31 / Samsung Microwave Magnetron Wb27x10516 Logo
22 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
