Question about Dell 924 All-in-One InkJet Printer
Dell c1760 false paper jam, no paper visible but don't see how to open so I can see inside.
SOURCE: Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Posted on Apr 12, 2008
NitrusInc
  • 326 Answers
SOURCE: I have a Dell W5300 printer. After removing all
Have you attempted leaving the printer unplugged (if possible in the on position) for a period of 5-10 Minutes?
Posted on Apr 13, 2009
dryden3
SOURCE: printer 948 false paper jam
Tonight, I fixed my neighbor's Dell 948 printer with false paper jam.
After you lift open the top, look below the shiny bar that the Print Head slides left/right on. You'll see a row of 8 tiny rollers. In between the middle two rollers (rollers #4 and #5 from the left), look for a small plastic tab sticking up between them. Touch this tab with the tip of a ball-point pen to see if it pushes down. If it does, then push the "checkmark" button on the control panel.
That's what I did to fix my neighbor's printer.
Sincerely,
John
Posted on May 05, 2009
devdeep545
  • 137 Answers
SOURCE: Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Posted on Aug 09, 2009
SOURCE: dell 948 false paper jams
Posted on Jan 09, 2010
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Clear the paper jam message but there is no paper jam
Hi
To clear the paper jam check for any visible paper jams. If there are none then remove the toner cartridge and inspect for any bits of paper stuck under there. Hold the printer upside down and try and shake it gently to remove small bits of paper. Open the rear door of the printer and try to find any visible paper stuck. After this turn on the power to the printer. Hope this helps... Please post back if more help is required.
Daniel
Nov 08, 2010 | Dell 924 All-in-One InkJet Printer
Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 07, 2009 | HP Photosmart C7280 Laser Printer
Apr 13, 2009 | Dell Office Equipment & Supplies
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
Dell 942 All-In-One InkJet paper jam
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. Up-grading the printer firmware could also fix this kind of issue, however I would appreciate if you try the steps below before you up-grade the printer firmware.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
If the above mentioned steps do not fix the issue please up-grade the printer firmware form the Support.dell.com web site. However make sure that you do not turn off either your printer or computer when you are downloading and installing the printer firmware.
Alternately you can also try to download the and install the printer drives form the support site if the paper jam message is being displayed on the computer’s screen but not on the printer’s LCD screen.
Should you require any further assistance regarding the printer or even any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Dell 942 All-In-One InkJet Printer
Dell photo printer 942 all in one paper jam
Regards
Malik Khan
Need help with printer dell 942 paper jam
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Nov 27, 2007 | Dell 942 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
1,659 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
