Question about Konica Minolta Office Equipment & Supplies
Konica bizhub c550 is giving errow code c-3921
4 Suggested Answers
  • 30 Answers
SOURCE: Printing consecutive page numbers on multiple documents
look in applications (mainscreen) and I thinkit's under stamps/overlays. You might even be able to choose what page number to start with
Posted on Feb 25, 2009
  • 3 Answers
SOURCE: how do i replace staples
Section 8-37 in the manual tells you how to change the staples: ftp://software:03083jDi@207.18.56.26/software/BPG/bizhubC550UserGuideCopyOper.pdf
Posted on Mar 01, 2011
Daniel S
  • 4323 Answers
SOURCE: konica bizhub c550 is giveing me error code c-2a03
Hi
C-2a03 is a magenta toner cartridge eeprom access error. You can clean the connections between the toner cartridge and the machine if dirty. Try reinstalling the toner cartridge, if the cartridge is bad it should be replaced, if the cartridge is fine then the PWB-M should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 20, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Bizhub c550
replace the drum and developer unit. try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 14, 2014 | Konica Minolta Bizhub C550
ERROR CODE 3921 BIZHUB 450
replace the fuser unit.
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Then reset.
use this procedure:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Feb 03, 2014 | Konica Minolta bizhub C450P Laser Printer
ERROR C-3921
Jan 30, 2014 | Konica Minolta Bizhub C550
C-4501 konica minolta bizhub c550
replace the LASER assy. or what is called the printhead
Jan 13, 2014 | Konica Minolta Bizhub C550
What is the causes half printouts in black color in konica minolta bizhub c550
write unit block the signal just try to look for the object that block the signal from write unit
Oct 14, 2013 | Konica Minolta Bizhub C550
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
C5356 at Konica Minolta bizhub C550
Fan! Rear of machine TOP. Middle fan
Feb 26, 2012 | Konica Minolta Bizhub C550
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
