Question about Acer Aspire 4736Z 4736G 4738ZG 4733Z Keyboard Protector Cover Skin
System IP Address not found and says Media is Disconnected ? I have tried ipconfig /release and ipconfig /renew but didn't get result...Please solve this problem
  • 1,511 Answers
Re: Communications
Background
  • IP addresses are four numbers separated by periods. The four numbers can each range from 0 to 255. They are used on the Internet and on local networks. A current Internet IP address is 74.59.119.24. Local network IP addresses all start with 192.168 and an example is 192.168.0.101.
Identification
  • When the IP address of each computer on the network is checked, two will be the same. The IP address of a computer can be found by running "cmd" and then "ipconfig" in the black pop-up box which appears. Each computer will show an address like 192.168.xxx.yyy and two will be the same, resulting in the conflict message.
Solution
  • The IP address of one of the two machines which has the same address will have to be changed. IP addresses are set in the Network Properties section under Protocol (TCP/IP). The last three numbers of one of the conflict machines must be changed to a number different from all the other IP addresses. The machine must be restarted and the error message will no longer appear.
Posted on Jan 07, 2014
Lost IP address in settings
press the reset button on the router and unplug it,now search for wireless with your comp,click on your router and enter admin password
Jun 27, 2015 | Dell Inspiron 530 Desktop Computer
What does computer command "ipconf/release" do?
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
Sep 03, 2014 | Lenovo ThinkCentre Computers & Internet
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
Dap 1160 Problem access web admin page
connect device directly to your computer using Ethernet cord. try to release and renew IP from the command prompt
IPCONFIG /RELEASE
IPCONFIG /RENEW
IPCONFIG /FLUSHDNS
then perform ipconfig. From there you will be able to get the IP address of the access point that you will need when accessing web admin page
Dec 22, 2012 | D-Link DAP-1160/B ACCESS POINT, WLESS G,...
EEE PC, Win XP, TCP/IP and DCHP does not work, cannot renew IP address.
flush and renew your ip address via this commands:
*click the start menu*select "run"*type "cmd"*press enter*you will have a black screen*type ipconfig/release*then it will release your current ip address*type ipconfig/renew to renew the ip address then you're good to go.
Dec 27, 2011 | Computers & Internet
My acer aspire 5630 will no make the connection to the internet using the wireless. if i hook it up hard wired it works fine. I also tried a USB wireless but it would not make the connection that way...
Try to release and renew the IP address:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Dec 13, 2010 | Acer Aspire 5630 Notebook
I could not check my ip address using cmd prompt. I typed IPCONFIG it results in showing media disconnected. What i have to do for this?
plug in ur network cable. rt click on my network places go to properties there u dbl clik on tcp/ip change to obtain ip address automatically. apply n exit. after 1 min try running the cmd n type ipconfig/all if not found type ipconfig/release then again ipconfig/renew u will get it.
Aug 07, 2010 | Computers & Internet
How to release and renew the IP address in Win Xp.
Go to start
Go to run
type cmd
to renew the IP command is
ipconfig /renew
to releaed the command is
ipconfig /release
May 03, 2010 | HP Pavilion dv6000z Notebook
IP ADDRESS MISSING ON LAPTOP
I think if you open start then type cmd then in black window type ipconfig/release then ipconfig/renew this should fix your problem if you have a network connection
Apr 01, 2009 | Dell Inspiron 1501 Notebook
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
Tips:
Oct 28, 2008 | Gateway Computers & Internet
Acer Aspire 4736Z 4736G 4738ZG 4733Z Keyboard Protector Cover Skin Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
