Belt life fuser life
    New Friend:
I need the example letter for resign
Posted on Jul 30, 2013
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Want to know life expectancy of the 6180
a new fuser should be a lot cheaper than a new printer
Mar 26, 2014 | Xerox Phaser 6180N Laser Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
May 16, 2011 | Xerox Phaser 6180N Laser Printer
There is a warning said : " fuser unit end". What is the problem for that printer HL-4040CN? Even after I changed the drum unit and belt unit, there are still 2 warnings appearing to ask for...
first you are talking about the FUSER END message that means you have to change the FUSER and as for the DRUM and BELT you have to RESET the TIMER to tell the printer that it has been changed as well as for the FUSER those are consumable parts they have a life and the printer is programed to tell you to change them after so much copies.
Jan 05, 2011 | Brother HL-4040CN Laser Printer
When should the fuser and rollers be replaced on the Dell 3110cn?
Fuser life is 100,000 pages.
Pickup and transport rollers - replace when defective - no 'fixed' life, but if you are replacing fuser, it's worth changing the pickup and transport rollers at the same time.
Note Transfer belt also has a 100,000 page life.
Mar 05, 2010 | Dell 3110cn Laser Printer
Oki 5150 color are not print right
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Jun 25, 2009 | OKI C5150n Led Printer
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
77 people viewed this question
k24674
jasbo
jasbo
