Question about Home
Triton delta 7 shower leaking from back of unit
    Master:
  • 966 Answers
That leak will damage the walls and ceiling below. If you cannot find the leak visually, call a plumber before much damage is done.
Posted on Aug 02, 2013
Testimonial: "sorry i probably didn't give you enough info the water comes from between the backplate and the tiles is always cold and flows away into the bath thanks anyway"
cballard
  • 18 Answers
SOURCE: what is the wattage of a triton delta shower
The only Triton Delta i find is 8.4W
Posted on Dec 11, 2008
  • 659 Answers
SOURCE: my shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Posted on Apr 03, 2009
  • 297 Answers
SOURCE: Leak in hand held hose, Delta In2ition
you must be missing a washer or gasket that goes in the hose end, of the hose try teflon tape,this is all your plumber is going to do.
Posted on Jul 17, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
  • 16 Answers
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
sounds like the pump is broke. better off just replacing whole unit unless you order new pump from triton.
Posted on Jan 10, 2010
How do I replace a Delta shower faucet with a new one?
should not be necessary to get behind the shower stall as there should be a hole big enough to remove /replace the facet insert
call a plumber in as it may be corroded in place and may require specialist tools for the job
get a quote first
Jun 30, 2016 | Delta & Single Handle Shower Faucet
TRITON SHOWER WATER LEAKING DOWN WALL AT THE BACK
Sorry to say most parts are plastic and sometimes deform,the cost to repair could be more than a new unit.very easy to swap,bite the bullit
and replace
Jul 01, 2014 | Grohe 25 597 Talia Tub Filler w/Personal...
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
I have a leak under my bathtub/shower it only leaks when the shower is on.It's not the drain or the pipe up to the shower head
There may be some leakage in pipe.Take the help of experts.Nowadays there are many leak detection services that can help in solving such problems.
find a leak in wall
Aug 02, 2012 | Delta Faucet Delta RP17453 Pull-Down...
Triton sentiment shower leaking
how do you tell the difference between the old triton sentimate shower and the new one.. please someone help
Jan 28, 2012 | Home
My triton shower blew its fuse a couple of times and came back on when I 'flipped the switch' back up. Now it's given up altogether. What's the problem?
Assuming that the circuit and fuse protection you have is correct for the kw rating of shower unit the most likely cause would be an element failure however in order to be more definate relevent electrical checks would be required within the shower unit.
The Triton Service Dept who may be contacted by telephone on 0844 980 0750 would be able to arrange a sevice visit for you where the problem may be investigated further for you.
Regards,
Karl
TRITON TECHNICAL TEAM
Oct 05, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
May 18, 2009 | Delta & Single Handle Shower Faucet
What is the wattage of a triton delta shower
Dec 08, 2008 | Home
Home Logo
104 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
