Question about UPS Battery Backup Systems
I have a Leviton UPS with 6 outlets. Problem is I plug it up (with or without anything plugged in one of the 6 outlets) turn the toggle switch on. Then I get a normal green LED. Within 5 seconds the orange LED flashes about 4 times, then about 10 seconds later the unit trips off. I have checked internal fuses, checked the power cord with ohm meter for a short. Battery is fine, no sign of any thing on pc board getting hot. Anyone have any suggestions?
This problem may be due to over charging voltage
Thanks & regards
Posted on Jan 09, 2008
  • 82 Answers
Dear, This problam is related to battery and i am sure your battery is faulty pls replace it.
Posted on Sep 25, 2007
0 characters
3 Points
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Hi,do I have to keep my ups plugged to a wall socke all the time?
the unit needs to be plugged in all the time. the unit is or should be fully automatic. higher priced units have a usb cord so you can check their status right on the computer, does your ups have a usb outlet? you might want to take it up to a computer store and buy a usb cable and then you can control your UPS with your computer. manually turning the UPS on and off shouldnt hurt anything.
good luck
Aug 01, 2010 | APC (BE500U-WEB) (BE500UWEB) UPS System
When the power button is turned on my apc350 makes a high squeal sound, what is this? I have to have it turned on to use anything that is plugged into the battery backup outlets.
Double check the connections on the internal battery. If you have had the unit for a year or longer it may be telling you your back up battery isnt any good. I suggest replacing the battery, go here
Mar 15, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
I have an APC BE350U battery backup. When power is removed, all connected equipment stops and the unit beeps four times every 30 seconds. I have removed the battery from the case and checked the power...
The output on the battery should be around 14V, not 115V. If the unit is not holding the equipment powered when you remove the power, you need to get a replacement battery. The BE350 uses a 12v 3.5. Make sure to buy a high quality battery in order to get a good and reliable run time.
Jan 29, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
My ups battery brekar trips freqvently
UPS battery backups sometimes come with two ratings, one is continuous use, and the other is Peak use. In other words if you stay at the continuous load and it isn't in a hot area, or in a place where heat can build up (excessive heat lowers the UPS rating alot) you should be fine, but if you are over that rating and into the Peak rating for more than 10 seconds or so (varies) it will trip to protect itself. Or it could simply be a faulty breaker. Look at how much load you have
Just in case you dont already know, the way to tell how many amps any UPS can handle is to divide the va by the supply other words a 1200va UPS plugged into a 120v. outlet will handle 10 amps, but if you want a UPS that you are going to use at 10 amps you would want one that was rated for 1200va continuous, or better yet, go up to a 1500va and it will never let you down. Good luck.
Nov 06, 2009 | Emerson PowerSure Personal 500VA...
Has started to beep whenever items plugged into
If it's more than 3 years old, you probably need new batteries.
If the beep started after plugging anything additional into the UPS, you may be in an overload state, and the beep is telling you that it's choosing to beep and not function as intended rather than smoking itself. Try unplugging a piece or two from it and see if the beep goes away. If not, probably just you're batteries giving out due to old age, they'll only give you 3-5 years.
Oct 11, 2009 | Dynex UPS Battery Backup Systems
APC ES-350 won't turn on; all I see is a blinking light.
Try looking for a small circuit breaker on the side that says "press to reset" - you could have tripped it accidentally when you unplugged the iPod.  Also, try pressing and holding the UPS power switch for 10-15 seconds.  That should force a power on as well.
May 27, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Battery Backup/Surge Protector Question
Considering the low draw of power you intend for the UPS it will work well. I have two monitors on a strip plugged into UPS along with desktop, routers and modems, UPS handles all well, it's just shortens battery backup times. Have had to power down from outages several times without any probs.
Jan 30, 2009 | APC Back-UPS RS Battery Backup (apw...
UPS Battery Backup Systems Logo
526 people viewed this question
Top UPS Battery Backup Systems Experts
Jax Planet
Jax Planet
Sudeep Chatterjee
Sudeep Chatterjee
Are you an UPS Battery Backup System Expert? Answer questions, earn points and help others
