Question about Garden
Transmission slips and bangs going down hill on my LT 1040.
3 Suggested Answers
SOURCE: MTD Yard machine Lawn mower. Slips and jerks while
Did you find the problem with the rider slipping when going down hills, I have one that is doing the same thing, I changed the belts, but that still did not help. It does not do it going up hils in forward gear, or going up or down in reverse. Thanks Bob
Posted on Aug 02, 2010
  • 599 Answers
SOURCE: TRANSMISSION SLIPS WHEN GOING UP HILL PUSH CLUTCH
You have to adjust the tension on your belt, or if there is no adjustment you may need to replace the tension spring, or possibly the belt is worn to the point of excessive slipping.
GOOD LUCK.
Posted on Aug 24, 2011
Problem with 2011 Ghevy Malibu 4DR SDN LT
Check your Transmission fluid Level, That is the Slip
Apr 09, 2013 | Cars & Trucks
My 2006 Mazda3 increases RPMs and slows down going up hills
there may be a mechanical problem in the trans mission with that mileage it may be that it needs overhauled try a transmission specialist not the dealer
Jan 22, 2013 | 2006 Mazda 3
Slipping transmission
if manual shift drive plate {clutch} if auto tork convertor
Aug 18, 2012 | 1994 Ford Taurus
Gutless on hills....only 60,000 miles
Usually a problem such as yours, there are 2 areas of concern:
  1. Transmission slipping - if the transmission isn't kicking down to provide power on hills, you may have a slipping problem. Transmission fluid and filter should be changed every 30k. Could be low on transmission fluid or the fluid could be old and/or burned (will be brown instead of purple)
  2. Fuel obstruction - common fixes for a fuel problem are fuel filter, clogged fuel injector
Aug 05, 2011 | 2003 Hyundai Santa Fe
My car slip when going down the road and pulling a hill
Transmission Slips ?
Should have stopped driving it
a long time ago
Need to go to a trans shop & have it
rebuilt or replaced with a CERT (Reman)
Jun 25, 2011 | 2000 Pontiac Montana
Transmission multiple shifting/banging under load
start engine chock back of drive wheels ,put in reverse and then check oil level
Jul 02, 2010 | Lincoln Continental Cars & Trucks
Transmission is slipping getting into gear. It
How many miles? Ever had your transmission serviced? The cheapest way to determine if you need to have your trany replaced is to change the fluid and filter. Also add a quart of good transmission additive. You may want to try the no-slip additive first. Either way it will cost you about $80 if you do your own work.
Oct 15, 2009 | 1994 Jeep Grand Cherokee
Clutch slips in high gear when I give gas going up hills in 94 nissan pickup. can I ajust it? thanks
might able to adjust it, but it wouldnt be worth it
if it slips when alot of resistance is put the the vehicle, it requires a new clutch for sure.
Jun 16, 2009 | 1994 Nissan Pickup
NO POWER / SHUDDER
Is it a standard or automatic transmission? If standard, your clutch may be slipping. While driving down a straight road, push the brake while still in gear and push the gas pedal as well. If the engine slows with the vehicle, the clutch isn't slipping. If the engine speeds up while the vehicle is slowing down, the clutch is slipping.
If it is an automatic, check the transmission fluid. You may be low and the transmission is slipping while under load, or the torque converter is slipping for the same reason. You may have a bad torque converter clutch switch, but the computer should have picked that up and made your "Check Engine" light come on.
These are the main reasons you would be losing power going up hills unless your engine isn't powerful enough to handle the larger tires on extreme hills. (It takes more power to turn a larger wheel going up hill since the vehile has to travel further for each revolution of a larger tire. Incidentally, have your speedometer checked. You will be going faster than what the speedo says since you put larger tires on.) Good Luck.
Aug 19, 2008 | Volkswagen Golf Cars & Trucks
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
