Question about Garden
My mower just stopped going when I was cutting grass. It will not move in forward gears or reverse. I lifted the mower off of the ground and spun one of the back wheels and the wheels move in the opposite direction from one another. What could this be and how to fix it?
  • 1,807 Answers
That is normal if it has a rear dif/gearbox, they are ment to turn in opposite directions. Does your machine have a leaver to disengage the drive for recovery purposes.? This may have knocked the machine out of drive.
Posted on Jul 30, 2013
  • 2 more comments
  • justin hamilton Jul 30, 2013
    I can put it in all the gears but the mower will not move. It tries to move barely while in forward gear but just will not move.
  • Plink-plonk
    Plink-plonk Jul 30, 2013
    What is the ake and model of the machine, maybe i can find a workshop mnual for it.
  • Plink-plonk
    *make
    New Friend:
  • 14 Answers
I have checked the belt an everything is there a kit an diagram i can get to rebuild it an it is a GTH2654T
Posted on May 11, 2014
lester482529
  • 226 Answers
SOURCE: Mtd mower will not move forward or backward.rear
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
Posted on May 31, 2009
  • 3 Answers
SOURCE: Tractor will not move in forward or reverse.
check hyd pump drive belt
Posted on Jun 18, 2009
SOURCE: My jd stx38 riding mower doesn't go forward or reverse after I re
Check the drive belt but if this is a hydro you probly have a bad trans. Best bet get a new mower.
Posted on Jan 08, 2010
vincob
  • 718 Answers
SOURCE: MTD 14/32 lawn tractor 16 years old. Cutting grass
If your belt is connected to a gearbox then you need to go inside the gearbox and see what is holding up forward motion I think it could possibly be a broken tooth on a gear or something inside gearbox stopping your forward motion. Shot in the dark maybe but it's worth a try if your handy. Good luck!
Posted on Aug 14, 2010
agent91
  • 2100 Answers
SOURCE: I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND
2 things, one, the belt jumped track, broke, or melted in place, 2, the hydrostatic ****** is out of oil, you didn't say if it was hydro or not. I doubt that the gear box has gone bad, but I would put more blame on a belt or pulley. Check it out. Hope this helps.
Posted on Mar 18, 2012
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 | Toro Garden
Mower was moving & just stopped
You'll have to take a cover off where the drive is for wheels as there is probably a belt there
Sep 12, 2014 | John Deere Original 130 160 165 175 180...
My Weedeater riding lawn mower will not move in forward or reverse after it has started
Check your drive belt that it has not slipped off.. also check your drive lever on the right side (speeds, neutral, and reverse). The mower uses this lever to angle the motor against the belt to move it..
It is most likely the belt or the angle misaligned if the engine is turning...
Apr 21, 2013 | Weed Eater Weedeater 26" Riding Mower
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I WAS RIDING MY MOWER, WHEN I DECIDED TO CUT SOME GRASS, I STOPPED THE MOWER, PUSHED IN THE CLUTCH, ENGAGED THE BLADES, THE BLADES STARTED MOVING, I THEN PUT THE MOWER IN FOWARD LET OFF THE CLUTCH AND...
Mar 17, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
MTD 14/32 lawn tractor 16 years old. Cutting grass then stopped. Belts smoking in forward. Will go in reverse. Changed belt and does same thing. In neutral and in gear wheels will not turn???
Aug 13, 2010 | Garden
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
May 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
