Question about Northstar Explorer 567 Chartplotter GPS Receiver
My 557 screen has gone black. The plotter seems to work as it communicates with the VHF but I cannot see the screen and it is not dimmed or in night mode. Seems the screen is burnt out. Is there a fix or somewhere I can find a replacment 557/567?
Hi I have blank screen too. Have you found a solution to the problem? Thanks Gerald
Posted on Jan 24, 2015
Vm321 infrared leds stoped working
it might be cause of open infrared diode or shorted
Nov 28, 2014 | Vtech VM321 Video Baby Monitor 1 Camera...
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Hope this is helpful.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
I have an LG 42" plasma tv (model: 42pc1da) and I am having a major picture problem with it. Last night, while watching the television, I heard an audible "pop" and the picture started to dim. I turned the...
The sound you heard came from one of the IC's under the heat sinks. Check the fuses on the left and right print, the print with the broken fuse must be replaced.
Sep 03, 2010 | Televison & Video
Downlading manual in DANISH or ENGLISH for VHF
Hi!
Here's the link to download the manual for the Simrad RS82:
Unfortunately, there doesn't seem to be a Danish version listed:
http://www.simrad-yachting.com/Products/Professional/Communication-Systems/RS82-dVHF-Radio-System/Downloads/
Hope this helps!
Aug 31, 2010 | Simrad Rs82 Handset Vhf Radio
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Compaq V2000 Display blacks out
sounds like the backlight has gone....test with an external monitor....if the external monitor works without any problems...the backlight has gone...better to get a professional to do this as its kind of fiddly and involves taking the screen apart
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
How do i print the usage page
You should be able to communicate with the plotter and get a control screen, through your browser, by typing in it's ip address. (i.e. 192.168.1.xxx)
Also, from the plotter, under utilites, you can view/print a usage report.
Nov 23, 2008 | Office Equipment & Supplies
Northstar Explorer 567 Chartplotter GPS Receiver Logo
149 people viewed this question
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
