Question about Boating
Engine quits at full throttle, no warning. Won't start for awhile after
What make and model of engine is it? Inboard, outboard? Petrol, diesel? How long does it run before it cuts out? Does it get hot or does it stop while still cold? It sounds like a petrol supply problem, but the cause could be electric or fuel. A fuel restriction such as clogged filter could do it, but an electrical fault could also do it as the temperature increases. I tend to think it's more likely fuel though but don't have enough info. I'll look out for your reply
Posted on Jul 31, 2013
Engine stslls while driving usualy starts back up. now wont start .have fuel,new throttle position sensor, idle air control,sounds like pump is getting,help????
you don`t say how you know it has fuel. did you check the fuel pressure with a gage and did you check the fuel volume as well. this sounds like a fuel pump problem.
Aug 31, 2015 | 1998 Dodge Dakota
While driving the starting disabled warning came on and the car quit. after 3 tries it started and seems ok. what happened?
It just said starting disabled , nothing else ?
Starting Disabled (Due To Electronic Throttle Control)
Starting Disabled (Due To Theft System)
No other lights ? Service Vehicle Soon , check engine , security ?
Reduced Engine Power message ?
Aug 23, 2015 | 2008 Buick Lacrosse
Engine runs full throttle and won't throttle down
Try grabbing the governor arm coming out of the side of the engine where the throttle linkage comes from, can you manually slow the engine down with that? Is it stuck?
Jun 09, 2013 | Cub Cadet Garden
1994 Nissan truck quits while driving
TRY CHECKING THE THROTTLE POSITION SENSOR, OR A LOOSE GROUND WIRE IN ENGINE COMPARTMENT NEAR THE ECM.
Dec 25, 2012 | 1994 Nissan Pickup
Yamaha outboard engine. Model f20leha manufactured 5-2011, has about 30 hours on it. Sinse new engine is hard to start, after finally getting engine started, hard to keep it running untill engine gets...
have you left the choke open ? this mixes more fuel to the engine upon starting but will stall it if left open too long . check your fuel filter too it may be full of debris.
May 02, 2012 | Yamaha Boating
1987 300 zx starts the quits after 2 minutes and won't start again
probally crank sensor. starts then stalls after driving a few min. then won't start for awhile. u can actually check it on the ecu. 4 green lights then 4 red lights. if you can't run the comp check on ecu let me know i'll look it up its been awhile had same prob years ago all my sensors are new
Oct 28, 2011 | 1987 Nissan 300ZX
My 1994 kawasaki 750 ss jet ski will only go half speed when I have the throttle wide open?
Is it bogging down, or just stops revving at the point...first check the throttle cable, twist it wide open and make sure it's opening all the way...after awhile they tend to stretch and that won't allow you full power....i hope this helps.
Aug 29, 2011 | 1989 kawasaki GTR 1000
Friend has a 200 hp EFI oil injected 2 Stroke outboard on a ski boat and is experiencing power restrictions when he opens throttle up. Motor will not do this if throttle slowly opened but again when at...
I run a 175 Evinrude set up similar to this one.
If there are no warning lights or warning beeps you will have a restricted fuel filter or fuel line.
The reason you can throttle up slowly is because it takes less fuel flow to get to that point that way.
And at full throttle it takes more fuel flow to maintain speed.
If there are warnings you will need to get it scanned to find out the cause and have it repaired. Warnings can slow down the engine to help prevent engine damage.
Dec 26, 2009 | Boating
Craftsman garden tractor quits when brake released.
It sounds like your throttle cable is caught up with the brake pedal.
Oct 01, 2009 | Garden
Boating Logo
47 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
