Question about Fujitsu Siemens LifeBook E8020 Notebook
Aero driver wdmm - Fujitsu Siemens LifeBook E8020 Notebook
    Master:
  • 663 Answers
If you are looking for a driver update then I suggest that you install RadarSync which is an automatic driver updater.
David
Posted on Jul 30, 2013
Aero drivers w 7
Try to find the correct drivers
Sep 06, 2014 | Acer Aspire E Series 14" Laptop - 4GB...
Tip
"Aero features are'nt running in window's 7"
Solution: Check that your computer meets the minimum hardware requirements for running Aero:
1-gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) of random access memory (RAM)
128-megabyte (MB) graphics card
Aero also requires a DirectX 9 class graphics processor that supports a Windows Display Driver Model Driver, Pixel Shader 2.0 in hardware, and 32 bits per pixel.
For best results, you might also want to follow these graphics processor recommendations:
64 MB of graphics memory to support a single monitor with a resolution that is less than 1,310,720 pixels (for example, a 17–inch flat panel LCD monitor that has a 1280 × 1024 resolution)
128 MB of graphics memory to support a single monitor with a resolution from 1,310,720 to 2,304,000 pixels (for example, a 21.1–inch flat panel LCD monitor that has up to a 1600 × 1200 resolution)
256 MB of graphics memory to support a single monitor with a resolution greater than 2,304,000 pixels (for example, a 30–inch wide-screen flat panel LCD monitor that has up to a 2560 × 1600 resolution)
To turn on window frame transparency, the color scheme must first be set to Windows Aero.
1.Open Personalization by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
2.Click Window Color and Appearance.
3.Select the Enable transparency check box.
To change the color scheme to Windows Aero
1.Open Appearance Settings by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Window Color and Appearance. If the Appearance Settings dialog box is not displayed, at the bottom of the page, click Open classic appearance properties.
2.In the Color scheme list, click Windows Aero, and then click OK.
Check that your theme is an aero theme and not a normal theme. Themes are available in normal and aero and can be confusing. Set your theme as an aero theme and you should get the aero window working.
These steps will help us to have AERO running.
Thank's and Regard's:
Pcs365.8
on Jul 13, 2010 | Computers & Internet
I have a 20 inch lg lcd monitor..I am using a pentium 4 processor with 101 intel motherboard..I installed windows 7 ultimate but I cant find a display driver from lg for this. I cant experience AERO...
In order to experience Windows Aero effects you generally need to have a minimum windows experience base score of at least 3.0. To determine your score go to your start menu - control panel - system and maintenance - performance information and tools.
In this screen you will see your score for a number of different components of your computer. One of these is graphics, which is the score for running windows aero. This score generally needs to be at least a 3.0 to get all the functionality of Aero running smoothly on your computer. The only thing you can try to do is update your graphics drivers to see if this can increase your rating. This can sometimes be done through windows update. The LG driver unfortunately will not be able to help you in this regard as it is only a driver for the display, not the graphics capabilities of your computer.
The only option would be to look into getting a new video card. With a new one you should be able to experience Aero effects again.
Sep 08, 2011 | Computers & Internet
How can i used aero in windows 7 ultimate
Basically if your laptop''s Video Card or GPU has already the minimum requirements to run windows aero it will be automatically be turned on upon installation of Windows 7.
However in some cases windows aero will not be enabled if your driver did not match your Video Card so remember to install the right driver for your Video Card.
A quick way to know that your laptop actually can run windows aero is by running the Windows Experience Index. Right click on computer then click properties. The score (both base score and subscore for graphics component) should be equal or higher than 3.0 for Aero to work.
Jun 25, 2011 | Clevo MOBINOTE M540SS LAPTOP LCD SCREEN...
When installing the driver for GUC2015v it disables aero in Win 7
To enable window aero you must have a graphics card with at least 64MB of RAM in it, although I’d suggest a card with more memory. If you have a lower memory graphics card, you may have to decrease the resolution to enable Aero. The IOGEAR does not have memory in it so it uses memory from your graphics card to display the other screen. So i would make sure you have atleast a 512MB video card to allow windows aero to load. Also make sure that you have installed the correct driver for the device, You driver can be downloaded HERE
Jun 23, 2010 | IOGear (GUC2015V) Video Capture
Intel 915pm WDDM Driver and Windows Aero
Install your Intel 915 chipset compatible driver and Intel VGA compatible driver (for Win7)
May 04, 2010 | Acer TravelMate 5602WSMi Notebook
760GXK8MC Aero problem
Only if the board's chipset driver is compatible.
Mar 30, 2010 | Foxconn 760GXK8MC-S Motherboard
The Aero feature is not working
http://support.asus.com/download/download.aspx?model=K8S-MX&SLanguage=en-us
follow this link and download ur driver and check it
Mar 01, 2010 | ASUS K8S-MX Motherboard
Is it possible to run vista aero on EliteGroup km400-m2?
Vista Aero is dependent on your Graphics hardware, not on your motherboard. The onboard VIA/S3G is not going to be capable of running Aero, but you do have an AGP 8x port that you could buy a card for. Try picking up an ATI 48xx series card if you plan on doing some gaming. If you just want to run Aero, however, just about any card nVidia 76xx series, 86xx, 96xx, or any ATI 26xx, 36xx, or 46xx series card will do.
Oct 19, 2009 | EliteGroup KM400-M2 Motherboard
Vista WDDM Drivers
Intel has no plans to release WDDM for this Chipset.
Sorry
Nov 10, 2008 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu Siemens LifeBook E8020 Notebook Logo
232 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
