Question about Konica Minolta Office Equipment & Supplies
Aidc sensor - Konica Minolta Office Equipment & Supplies
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 45 Answers
NEED MODEL
Posted on Aug 30, 2013
How to remove c-24
1 PJ7A, CN10, and CN41 are plugged securely into Master Board. NO Plug them in securely. 2 Photosensor/LED of the AIDC Sensor are contaminated. YES Clean. NO Change AIDC Sensor Board. Change Master Board.
Dec 16, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Di450 errer cod c-0f24
COF24 - AIDC sensor contamination correction failure.Open the front door,remove(lossen 2 screw)the image unit,remove the drum and clean photosensor/LED of AIDC sensor.
Jan 03, 2012 | Minolta Office Equipment & Supplies
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
Malfundtion code C0F30
Please specify the model.The COF30 code refer to AIDC sensor(auto image density control).Clean the optics part mirror,lens ansd sensors.
Nov 04, 2009 | Minolta Office Equipment & Supplies
AIDC error code
When an “AIDC Error” occurs, do this:
1. Replace the Image Transfer Belt
2. Check to see if the AIDC Sensor is dirty
3. Securely connect the connectors to the High Voltage Unit
4. Replace PWB-A
Aug 05, 2009 | Konica Minolta magicolor 5430 DL Laser...
Panel shows error code Cof24
AIDC sensor problem.Dle Vasile precizati tipul ,modelul aparatului ca sa va pot ajuta.
Jun 24, 2009 | Minolta EP1030/1030F CS/PRO Copier
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
