Question about Intel Fortran Composer Xe 2013 for Linux - Complete package 1 Year Support - 1 developer - Edu - DVD - Linux
Ifort: command line remark #10010: option
Ifort: command line remark #10010: option '-pthread ' is deprecated and will be removed in a future release. See '-help deprecated'
Why Is the VLAN Priority Configured on the S5700 Invalid?
Fault Symptom The outbound interface of the switch joins a VLAN in untagged mode. When the remark 802.1p command is configured on the outbound interface, the configuration is invalid.
Cause Analysis The configuration of the S5700(such as S5700-28P-LI-AC)is as follows:
traffic classifier test
if-match any
traffic behavior test
remark 8021p 2
traffic policy test
classifier test behavior test
interface GigabitEthernet1/0/1
port link-type access
port default vlan 10
traffic-policy test outbound
The outbound interface joins a VLAN in untagged mode, so VLAN tags are removed from packets sent by the interface.
Conclusion To apply traffic policy defining remark vlan to the outbound interface, ensure that the interface joins a VLAN in tagged mode.
Jun 22, 2016 | Electrical Supplies
Is the wii going to be discontinued?
Hello There :)
There is no official remark about the Wii being discontinued. I believe that that lack of availability is simply a marketing ploy. The Wii has been one of the most successful gaming consoles ever. I dont think that it will be discontinued in the near future. There are probably locations FULL of Wiis that just havent been shipped out yet.
Hope this helps! Thumbs up always welcome.
May 03, 2011 | Nintendo Wii Console
SEARCH GOOGLE USING E-SPEAKING
These commands are built-in. You do not have to add or program them.
Working with Applications
Say... Open Word
Open Excel
Open Email
Open Powerpoint
Open Internet
Open Notepad
Close Application
Close Window
Close Document
Scroll Down
Scroll Up
Start Word
Start Excel
Start Email
Start Powerpoint
Start Internet
Start Notepad
Minimize
Maximize
Scroll Left
Scroll Right
Browsing the Web
Browse the web using the following commands: Open Internet
Google Website
Yahoo Website
Altavista Website
MSN Website
eBay Website
e-Speaking Website
Go Back
Go Forward
Refresh
Dialog Commands
Sometimes a program will simply ask you for a yes or no answer to an alert box or dialog. Yes
No
Cancel
Affirmative
System Commands
You can control when e-Speaking is "listening" to you using these voice commands. Standby
Resume
Stop Listening
Begin Listening
Hello
Computer
Listen to Me
Add a New Command
Add Mouse Click
Moving the Mouse
The Mouse Movement option has to be checked on the Mouse menu. Mouse Left
Mouse Right
Mouse Down
Mouse Up
Faster
Slower
Stop
Mouse Clock One
Mouse Clock Two
Mouse Clock Three
Mouse Clock Four
Mouse Clock Five
Mouse Clock Six
Mouse Clock Seven
Mouse Clock Eight
Mouse Clock Nine
Mouse Clock Ten
Mouse Clock Eleven
Mouse Clock Twelve
Slide Left
Slide Right
Slide Down
Slide Up
Mouse Buttons
Select
Double Click
Right Click
Properties
Drag Item
Drag File
Drag Object
Release Item
Release File
Release Object
Mouse Jump To
Mouse One - Top of Window
Mouse Two
Mouse Three
Mouse Four - Middle of Window
Mouse Five
Mouse Six
Mouse Seven - Bottom of Window
Mouse Alpha - Left of Window
Mouse Beta
Mouse Charlie
Mouse Delta - Middle of Window
Mouse Echo
Mouse Foxtrot
Mouse Golf - Right of Window
Editing Commands
Doing some word processing? These commands may help perform common Windows functions. Select All
Edit Copy
Edit Paste
Edit Undo
Edit Delete
Edit Find
Delete Line
Find
Search and Replace
Moving the Text Cursor
These commands may help navigate documents. Left Arrow
Left One
Left Two
Down Arrow
Down One
Down Two
Right Arrow
Right One
Right Two
Up Arrow
Up One
Up Two
Page Up
Page Down
Beginning of Line
End of Line
Beginning of Document
End of Document
Simulating Keys
Enter Key
Home Key
End Key
Spacebar
Escape Key
Delete Key
Backspace Key
Tab Key
Dictation
Start Dictation
Stop Dictation
Standby
Resume
Train Word
Show Commands
Dictation - Editing
Delete that Phrase
Delete that Text
Delete Last Phrase
Delete Last Text
Strike that Phrase
Delete Last Word
Edit Copy
Edit Paste
New Line (inserts a line)
Next Line (inserts a line)
New Paragraph (inserts 2 lines)
Next Paragraph (inserts 2 lines)
Select All
Delete Key
Backspace Key
Reading Commands
Read All Text
Read Selected Text
Stop Reading
Pause Reading
Resume Reading
Skip Ahead
Skip Back
Read Faster
Read Slower
Phonetic Alphabet
You must really like using voice if you are into the Phonetic Alphabet. Alpha
Bravo
Charlie
Delta
Echo
Foxtrot
Golf
Hotel
India
Juliet
Kilo
Lima
Mike
November
Oscar
Papa
Quebec
Romeo
Sierra
Tango
Uniform
Victor
Whiskey
Xray
Yankee
Zulu
Feb 05, 2011 | e-Speaking
Where is water pump and drive belt located on 2003 corolla ? Dealer recommended it needs changing along with timing chain tensioner which they say is leaking oil . I usually fix my own cars after doing my...
Water Pump Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the engine coolant.
  3. Remove the right lower splash shield.
  5. Remove the 6 water pump mounting bolts. Remove the water pump and O-ring (except XRS). toy_car_18_eng_wtr_pmp_set_blts_sst.gif
  6. Using special tool 09960-10010 or equivalent, remove the water pump pulley bolts and pulley (XRS).
  7. Remove the 6 water pump mounting bolts. Remove the water pump and O-ring (XRS).
To Install:
  1. Install a new O-ring on the timing chain cover. toy_car_18_eng_wtr_pmp_blt_torque.gif
    Note: Bolt lengths are indicated in the illustration bolt (1) 1.18 inches (30mm) bolt (2) 1.38 inches (35 mm)
  2. Install the water pump (except XRS).
    1. Tighten the mounting bolts (1) to 80 inch-lbs (9 Nm).
    2. Tighten the mounting bolts (2) 8 ft-lbs (11 Nm).
  3. Install the water pump (XRS).
    1. Tighten the mounting bolts 80 in lbs (9 Nm).
    2. Install the water pump pulley using special tool 09960-10010 or equivalent. Tighten the mounting bolts 11 ft lbs (15 Nm).
  4. Install the right lower splash shield.
  5. Install the drive belt.
  6. Fill the cooling system.
  7. Check for leaks.
Oct 09, 2010 | 2004 Toyota Corolla
Fuel door release will not open
  • Remove fuel tank filler cap.
  • Push back release rod - 9 - by operating remote control unlock and remove bolt - 2 -.
  • Remove rubber part - 8 - from tank filler flange and swivel out tank flap unit - 1 - from side panel - 7 -.Assembly piece - 4 - and actuator - 6 - is installed.
    • Install tank flap unit - 1 - (rubber part rolled up) with hinge side first.
    • Bolt tank flap unit - 1 - and assembly piece - 4 - with bolt - 2 -.
    Tightening torques: Bolts - 2 - 1.5 Nm
    • Remove side luggage compartment trim.
    • Disconnect harness connector at actuator - 6 -.
    • Remove actuator - 6 - using special tool Socket wrench T 10010 from angled mounting bracket.
    • Remove actuator - 6 - together with release rod - 9 - from seal - 5 - and assembly piece - 4 -.
    Installing
    Installation is reverse of removal.
    Tightening torques: Bolts for actuator - 6 - 1.5 Nm .
  • May 27, 2009 | 2001 Volkswagen Passat
    Won't go past window xp logo
    You will need to launch Windows XP Recovery Console..here are your to options you have to perform this to correct your boot issue..
    Option 1: If you have already installed the Recovery Console loadTOCNode(2, 'moreinformation'); If you have already installed the Recovery Console, you can select it during your usual Windows Startup. To run the Recovery Console:
    1. During Startup, select Recovery Console from the startup options menu.
    2. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
    3. When you are prompted, type the Administrator password.
    4. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
    5. At any time, you can type Help for a list of available commands.
    6. At any time, you can type Help commandname for help on a specific command.For example, you can type help attrib to display the help on the attributes command.
    7. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
    uparrow.gifBack to the top Option 2: Starting the Windows Recovery Console from the Windows XP CD-ROM loadTOCNode(2, 'moreinformation'); If you have not preinstalled the Windows Recovery Console, you can start the computer and use the Recovery Console directly from your original Windows XP installation disc. If your computer is already in Windows and you want to add the Windows Recovery Console as a startup option, go to the next section "Adding the Windows Recovery Console as a startup option."
    1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
    2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
    3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
    4. When you are prompted, type the Administrator password.
    5. At the command prompt, type Recovery Console commands, and then you can refer to the commands that are listed in the "Available commands within Windows Recovery Console" section.
    6. At any time, you can type Help for a list of available commands.
    7. At any time, you can type Help commandname for help on a specific command. For example, you can type help attrib to display the help on the attributes command.
    8. At any time, you can exit Windows Recovery Console by typing Exit at the command line.
    May 21, 2009 | Acer Aspire 3000 Notebook
    Excell 2007 very slow to open
    Speed up Excel 2007 startup The Problem If Excel isn't running already, double-clicking a file will start Excel itself almost immediately, but the clicked file will be loaded only after about one minute.
    The Solution At least on Windows XP the problem can be solved as described below.
    1. Application Explorer
    2. Menu Tools
    3. Menu item Folder Options
    4. Tab File Types
    5. List item XLS
    6. Button Advanced
    7. List item Open
    8. Button Edit...
    In the dialog box that appears you need to make two adjustments:
    Application to perform action:At the end of the line after /e append a space character followed by "%1" (including the quotes)DDE Application Not Running:Insert new text: [rem see command line] (including the brackets) Details We experienced the problem after updating to MS Office 2007. My father noticed that an Excel sheet gets loaded immediately if you include the path of EXCEL.EXE in the command line. Loading documents via DDE, as Explorer does it, seems to take much more time, at least if the application is not already running. The modifications described above will pass the file path immediately when the application is started, the DDE command that gets executed later on is only a remark, as an empty field would result in passing the default action from two lines above that field. The /e seems to ensure that Excel will not open an empty sheet, so I originally dropped that because usually no empty sheet is opened when a file is specified. However I got a report from someone using /e, and as it didn't cause any harm for me either, I now suggest to leave it in place. If Excel is running already, additional documents will be opened via DDE as before, resulting in only one Excel process running.
    Word Time and again I've been asked whether I knew a similar trick for Word. Even without any tricks Word starts fairly fast, but even there adding "%1" gave me a slight increase in startup speed. I don't exactly know what this [REM _DDE_Direct] is. It looks like some kind of "special comment", that could have some effect despite being a comment. I decided to copy that comment to the DDE Application Not Running box, and could not detect any ill effects. I also kept the /n and the /dde on the command line, simply because I could find no harm in it.
    Uninstall If you try out these suggestions, but they don't work out for you, reverting to the way it was before might prove more difficult than you would expect. It seems the dialog where you make your changes will always append a %1 to the command line when you press OK and it isn't present already. The only solution I could find was using regedit to remove the %1 without using the dialog. The command is stored under the default key at HKEY_CLASSES_ROOT\Excel.Sheet.8\shell\Open\command. If you choose to revert the DDE settins using regedit as well, you can simply remove the whole ddeexec\IfExec subtree.
    Feb 02, 2009 | Computers & Internet
    Microsoft Office Outlook
    Run Outlook from a command line with the /cleanprofile switch appended to the command.
    To find the correct command line, right click on a shortcut for Outlook and go to Properties. Copy the information in the Target field and Paste it to the command line. If there is already a command option, remove it and add /cleanprofile after the closing quotation mark. (Add a space before /cleanprofile)
    For example, go to Start: Run. . and enter something like "C:\Program Files\Microsoft Office\OFFICE11\OUTLOOK.EXE" /cleanprofile .
    Then add a new profile. Be sure to check the check box for "Set as default profile". Note: You cannot see this option unless you click on the "Options >>" button.
    This should fix the problem.
    Jul 02, 2008 | Microsoft Windows XP Professional
    Intel Fortran Composer Xe 2013 for Linux - Complete package 1 Year Support - 1 developer - Edu - DVD - Linux Logo
    329 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
