Question about GPS
Have to return the transponder for replacement - how do I do that?
    Top Expert:
  • 12,223 Answers
You must look the 1)address of the supplier 2) Go to UPS or another and get the transporder in some box, wrapped with the address for supplier, and with your personal address 3) put some information inside of the box, telling about your problem, invoice,etc
God bless you
Posted on Jul 30, 2013
Where and how can I return the transponder?
notify seller for return policy
Jul 12, 2017 | Cars & Trucks
Can I use ez pass towing a camper
I sometimes pull a camper or trailer with my vehicle. Can I still use my transponder?
Yes. In this instance the equipment in the lane is designed to identify that your vehicle is pulling a trailer and you will be charged accordingly. However, if you think this will be a regular occurrence, you should call the Customer Service Center and have them send you a transponder programmed for the vehicle classification you use most frequently. You should never use your transponder in a vehicle type other than the one you initially requested (i.e. Car transponder in a tractor-trailer).
Return to top of page
Apr 29, 2017 | Cars & Trucks
HOW DO I PROGRAM A 2009 HYUNDAI TUCSON CHIP KEY ?
This type of work normally requires diagnostic or key coding equipment .
May 02, 2015 | Hyundai Cars & Trucks
HI I HAVE AN ACTYON SPORT THIS VEHICLE CUT OFF WHILE DRIVEING .Iran a diagnostic and it picked up transponder error the key light is flashing but this van does not have a transponder key plse help
If I'm understanding you correctly, you're saying you DO NOT have the master key that came with the vehicle, I will assume you're using the secondary or the valet key for the car. On most vehicles if you've lost the master key and now the "Transponder" is flashing, you're kind of out of luck. If it's like other vehicles, your TRANSPONDER is the vehicle IMMOBILIZER. Means the car won't usually even crank over. You can try to have it towed to the dealer and have them re-enable it (turn off the transponder) or they may have to replace the whole ECU, Transponder and a new master key in order to get your vehicle going again.
Nov 21, 2013 | Air Intake Hose Ssangyong Rodius 2 7xdi...
I cannot get my new optical mouse to work. GE98548. I have the USB receiver plugged into the USB port, pressed the button and the red light came on. I pressed the Connect button on the mouse and nothing...
Hi
Basics first (some or all of which you may already have considered).
I assume you have batteries in the mouse.
Check the manual for the correct sequence and procedure for introducing the mouse to the transdponder for the first time. Sometimes the buttons on the wireless transponder and mouse need to be pressed and held for a certain amount of time.
Sometimes there needs to be clear line of sight between the mouse and the transponder, depending on if the signalling is Infra Red or RF. Consider a Male to Female USB extension cable that allows you to plug the male end of the extension cable into the PC's USB socket and the transponder into the female end of the extension cable, enabling you to place the transponder in clear line of sight of the mouse.
You will know when the mouse is properly connected to the transponder because when you press the Connect button the transponder should blink in response.
Leaving the transponder connected to the PC, try connecting a wired USB mouse to different USB port to see if you can get a moving cursor with it. If the Hardware Wizard appears, you may need use it to install USB drivers that are already in windows but not yet installed and active. After this, disconnect the wired mouse and test the wireless mouse again.
Also check in your BIOS (see which key to press - often DEL or F2 -during boot from the menu at the foot of the first boot screen to enter BIOS Setup and check if Legacy USB function is on or off. If off, use the + or - (or sometimes page Up or Page Down) keys to toggle it to on > F10 > Enter > boot into windows and test USB wireless mouse again.
If none of these ideas solve the problem, the device may be faulty and should be returned under warranty.
I hope this helps.
Aug 24, 2011 | GE Wireless Optical Mouse
I have a question about a post you posted a couple of years ago. I hope youre still answering questions. It reguards the ETM on a volvo s80. You said that if the recall software was upload and the problem...
i dont think they will replace the computer for nothinig after a couple of years ,best bet is to go to scrapyard and get one their complete with the chip out of the lkey and the transponder and the transponder read box as well
Jan 13, 2011 | Volvo S80 Cars & Trucks
Does a 2003 ford escape have a transponder chip?
YEP YOUR KEY TRANSPONDER IS READ THROUGH THE KEYLOCK CYLINDER READ COIL BY IMMOBILIZER CONTROL MODULE BEFORE CAR WILL START.IF CARRIER FREQUENCY SIGNAL IS NOT 100 - 150 KHZ RANGE CAR WONT START.YOUR CAR HAS TRANSPONDER KEY.MOST ALL LATE 96 TO 2011 VECHICLE CAR KEYS HAVE TRANSPONDER KEYS TO STOP CAR THEFTS.
Oct 17, 2010 | 2003 Ford Escape
Repeated transponder issues with the lowrance 320c fishfinder
Reading the manual it does say that there is a temperature range for these. I"m not sure where you live but it might be cold enough that it is damaging the transducer in the off winter months.
Jun 01, 2009 | Eagle Fisheasy 320c Fishfinder
Immobiliser transponder not working
hi the transponder is the chip in the key my car is the same its the red bit on the key.... and there is a reciver around the ignition barrel where the key go's to start the car its a black circle with 3 or 4 wire's runing to it you can't by pass this but i have been told that some are made with an external P.A.T.S system (Immobiliser system ) but same are built in tio the e.c.u if its external it might be poss to bypass im also so sure you can buy a key coder off the net try googleing it i hope this is a help to you ......
Jan 04, 2009 | 1996 Ford Escort 4 Door
Unit keeps reverting Sim mode
It suggests that the transponder or wiring is faulty. I had the same problem and noticed the wire leading to the transponder was worn and exposed in a small area (it had rubbed against the aluminuium of the boat). I have yet to fix the problem - but it may mean a replacement transponder and connection!.
Dec 16, 2007 | Lowrance X47EX GPS Receiver
GPS Logo
16 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
