Hp 6735s laptop
The keyboard are not working most times he might work now and next minute it may not.
    Top Expert:
  • 12,223 Answers
Uninstall the driver , and get the drive update from your manufacturer supplier computer and install again.
See if the regional and language is o.k in your idiom
God bless you
Posted on Jul 30, 2013
HP 6735s will not boot.
Remove the battery, place the laptop in a warm, dry and sunny spot for several days so it dries out completely. Replace the battery and see if the laptop boots up.
If not then the laptop maybe beyond repair, especially when water was spilt on the laptop when it was running. This could have caused some electronic components to short out.
Feb 26, 2012 | HP Compaq 6735s Notebook PC
I am an owner of an HP Compaq 6735s Notebook PC. I have experienced the notebook failure. I am unable to start the computer at all. It just happened when I tried to restart it. I have noticed the...
my daughters hp 6735s had the fan running all the time issue, having got fed up with this I decided to try to fix it. I downloaded the service manual from the hp website and dismanteld the laptop to remove the motherboard. The fan defuser had some dust but not much, so I removed the heatsink that covers the cpu and gpu. I noticed the cpu did have thermal compound that was in contact with the heatsink, however the gpu had compound on the chip but nothing touching the heatsink. I cleaned the heatsink, cpu and gpu with degreaser, then applied new silver themal compound from maplin. I made sure i also applied a thin coating to the heatsink. I refitted the heatsink and reassembled the laptop. I powered on the laptop and instantly noticed the laptop fan running at half speed which it should do, I installed a program from a dvd and left the laptop running and so far so good. If we had left this any longer I suspect the solder under the gpu would have become molten and then we could have had another issue which maybe we could not have fixed. I hope this helps you if you have similar issues.
Jan 19, 2011 | HP Compaq 6735s Notebook
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
Hp 6735s when power on not display
next time please, give clear description about the problem,
according to my understand, your display not work but all other things work, (switch on,CD drivers,Keyboard indicating lights so on...)
if it is try this...
connect a separate monitor to your laptop, that port has behind your laptop. then you can get a display on it, check your laptop LCD display, or its connected cable which it is in side the laptop, if you do not a profession about hardware do not do it.
Feb 11, 2010 | HP Computers & Internet
My laptop compaq 6735s will only stay on for a few minutes before shutting itself off and not working for a long time. Also, the area where the port is for the laptops charger get's exteremely hot. I don't...
This sounds like *********** board is overheating due to probably dust and fan not working properly. Try using air can to blow some of the stuff of off the fan from the bottom of the laptop but make sure you dont tip the can over while doing this because the air turns in to ice and it will mess up you laptop. If just blowing air don't work then you have to open it and clean it up.Hope this helps.
Jan 11, 2010 | HP Compaq 6735s Notebook
HP 6735s laptop with AMD Turion X2, screen remain dark...
Try locating your memory sticks under unit, try taking them out and resitting them, try also resitting your hard drive.
if this does not work let us know
Jan 04, 2010 | HP Compaq 6735s Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hp 6735s screen blank problem
If you use it from the power cable does it work better? There is a known issue with the 6735s and power management settings from battery.
Oct 02, 2009 | HP Compaq 6735s Notebook
How to replace HP 6735s
It's right under/next to the processor fan, locating it should help you determine your best course. I would completely disassemble the laptop to remove the motherboard for the processor upgrade.
Feb 12, 2009 | HP Compaq 6735s Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
